My 1998 S70 has always had this issue. When turning right or left while signaling, after completing the turn I have to turn the steering wheel past center by about 10 degrees before the signal clicks off on its own. On every other car I've driven, the signal clicks off before the wheel gets back to center. Seems like something might be worn out.
Suggestions?
Turn signals turn off too late
ferocity02
- Been thanked: 14 times
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Mine clicks off on dead center or doesn't click off at all. I think dead center is normal. 10 degrees past dead center might be an issue. I don't know if there is an adjustment for this.
Knows enough to be dangerous
ferocity02
In every other car I've driven the signal clicks of 10-30 degrees BEFORE you return to center.
Is this a Volvo thing? I have to turn the wheel past center in the opposite direction of the turn to click off the signal, or turn it off by hand.
- Has thanked: 2200 times
No that is not normal. I'd remove the steering column covers behind the steering wheel and see if you can see what is happening with the spring levers on the turn signal lever.
Richard_TD
- Year and Model: 855 2.5 20V 1996
- Has thanked: 6 times
- Been thanked: 5 times
Indicator cancelling problems are normally caused by a loose or broken airbag clock spring casing.
1996 855 GLT 2.5 20V
Remember to disconnect battery before fussing with AIrbag stuff or you will get an SRS CODE AND A $150 Dealer tax to clear it
- 13 Replies
- 4218 Views
Last post by gswede
- 2500 Views
Last post by Volvo Kush
- 1528 Views
Last post by mod64
- 8900 Views
Last post by rhubarb
- 943 Views
Last post by MoVolvos
