What do you have for roadtrip support
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
The Stanley product is attractive in price but poor design.
JNCAIR 1700 Peak Amp Jump Starter with Air Compressor is perfect but expansive. What are you using?
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
AAA roadside service. They have towed my S80 once in it's 15 year life, and installed one emergency battery, and my spare tire once. For what AAA membership cost per year it is worth the peace of mind that comes with having emergency roadside service 24/7.
Mike has a air compressor and big roll around battery charger in the garage if I need to add air to a tire or charge my car's battery. Honestly I have never used the battery charger ever as before the battery fails in my 2004 S80 the alarm goes crazy and all sorts of messages appear on the message center in the dash. So I have learned to have the battery checked when the symptoms start though the first time I was stranded and AAA came and installed a battery as you want to avoid jump starting a modern Volvo with it's complex computer systems.
The best way to avoid getting stuck in preventable breakdowns is to know your car. I know instantly when my car feels wrong. Ie if the car starts to pull one way I know to check the tires. Also if unusual sounds or vibrations occur they get my immediate attention. Also check all fluids under the hood at every gasoline fill up. And of course keep all maintenance up to date by miles or years as indicated in your cars maintenance manual.
So knowing my car, routine maintenance, and AAA is what I rely on for road support. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
I have spare parts with me to scare the originals into continuing to work. SO far it is almost 100% successful. I've had a fuel pressure sensor spare for 10+ years and never had a failure.
I have cheapo socket set and a few other tools wrapped in a beach towel under load floor. Towel in case I need to get on the ground. I don't think I've ever had to use the tools for breakdown.
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
June: As a preventative maintenance expert you should know regular charging will prolong the life of the battery quite a bit. They can last 15 years if kept well charged.
Rattnalle
Post by Rattnalle »
I mostly only go on longer trips with bikes in the car and then I have a bicycle pump and some basic tools.
Apart from that I've got reflective vests, a yellow magnetic strobe light, spare wheel and a long handle with a wheel bolt socket on it. And of course jumper cables and a towing cable. But that's pretty much it
xHeart
Post by xHeart »
Thank you.
We are back from the 2300 mile road trip to Black Hills, SD. Change of plan included NOT visiting Pine Ridge due to change of weather. And dropping I-80 altogether was best decision. But we did enjoy the drive down from Madison WI through incessant snow, rain and traffic for two hours.
How is our CN90 in Lincoln NE?
I-90 is joy to travel in SD and MN minus deer incidents.
okidiver
Year and Model: 2015 V60 2008 C30
Has thanked: 7 times
Been thanked: 3 times
Post by okidiver »
jimmy57 wrote: 20 Nov 2018, 12:08 I have spare parts with me to scare the originals into continuing to work. ...SNIPPED...
An ironic and most excellent strategy!
Been thanked: 4068 times
we have AAA with 100 mile coverage - and the only one who went to college >100 miles didn't take a car! One was 99 miles away - sweet!
Other than AAA and PM, I try to spread good karma everywhere I go, so if I am in a bind, I can get local help or even a place to drop a car and come retrieve on my time. So far, Ive got every where covered except Queens NY. No good karma there.
There are rumors that my T5 parking spot in Charlotte was recently vacated by an old R sitting there, too.
Rattnalle
Post by Rattnalle »
abscate wrote: 14 May 2019, 08:59 we have AAA with 100 mile coverage - and the only one who went to college >100 miles didn't take a car! One was 99 miles away - sweet!
Why would you need a support package that only covers pushing-distances? ;-)
xHeart
Post by xHeart »
okidiver wrote: 01 Dec 2018, 06:17
jimmy57 strategy includes carrying face-covers during road trip this summer -- scaring covid into staying away.
The TOPDON analyzer for Battery, Crank and Charge tests is good for checklist. It shows Ripple 374mV during Charging. Battery's Internal R is 3.47mV.
What is a good battery data?
