Replace heater core
thienle
- Year and Model: S80 2001 nonturbo
Replace heater core
Please advise if there are any instruction (with photos if available) of how to replace a heater core for 2001 Volvo S80 2.9L. And does the coolant require to be drained? Thank you very much.
- Has thanked: 2656 times
- Been thanked: 1248 times
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I believe it's better to drain the coolant indeed.
If the problem is no (or not enough) cabin heat, try first the Prestone Flush treatment
Don't forget to test the thermostat as well www.youtube.com/watch?v=gQxQnuU22Ow
If you decide to go with a new heater core, see this other video, gets you an idea as it's pretty much the same. The steering column that gets in the way can be slide either upwards or even completely removed by sliding it downwards - just mark the column before removing it (www.youtube.com/watch?v=atgnxtHoao8)
