Diary of a 17 y/o with an 850
shihabafi
Year and Model: 1995 850 Wagon
Has thanked: 50 times
Been thanked: 8 times
Re: Diary of a 17 y/o with an 850
Post by shihabafi »
misha wrote: 15 Oct 2018, 17:34It's a grease.
but... I've taken the wheels off many times and never put any grease on... Is this a cause for concern?
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Nope...it's advantage.
I usually put some grease on wheel lugs when i change summer/winter set of tyres when the time comes.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1500 times
Been thanked: 3812 times
Lube or dry lug nuts is one of those issues that consumes much too much internet bandwidth..like oil brands, oil change intervals, and Nitrogen in tires
Has thanked: 292 times
Been thanked: 765 times
shihabafi wrote: 15 Oct 2018, 18:02
Not sure what you're asking but no, don't be concerned about whether or not the lug bolts are greased.
Perhaps more to the point, the lug bolts have absolutely nothing to do with the squeak. I don't know what's causing it but it isn't the lugs.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
shihabafi
Post by shihabafi »
Dear diary,
The other day I took an exit off the highway, and when I turned, I admit I was going maybe a bit faster than a person should, but it wasn't "body-rolling" fast. Nevertheless, the arrow light and the check engine light started flashing, and the car stalled on me, while I was still rolling. Then I threw the car in Park and turned it back on and carried on.
I've known about this problem for a while, it's a wire that connects to the battery, and I'm assuming it's got something to do with the ignition coil. Anyways, when I got some time, I beat my car with a hammer, and now I doubt it's going to happen anytime soon. However, that doesn't mean I don't need to get it fixed soon...
Thats really easy to fix right. Its a really ugly mess as it is, and yes, will cause all sorts of electrical and running problems
shihabafi
Post by shihabafi »
Dear diary,
After having my license for just over a year, today I got into my first accident. I must admit, it was pretty scary. But there's good and bad news.
Good news:
We were all okay, I got off with a warning, insurance did not get involved, and her car was perfectly fine.
Bad news:
umm...
Most of the damage went to the glass in the lens. No idea how I managed to do that from a direct hit to the back, but no complains. Looks like I'll need to get a new turn signal lens cover, although that's tragic because this one was less than a month old. I took the grill out for the last picture. But the hood...
You think that'll buff out? :(
A panel beater can fix that. A nice bright yellow one will give it that Jerry Garcia look.
shihabafi
Post by shihabafi »
abscate wrote: 26 Nov 2018, 18:28 A panel beater can fix that. A nice bright yellow one will give it that Jerry Garcia look.
But I don't have one.... looks like it's off to the body shop... :/
misha
Post by misha »
It would be cheaper to replace the whole hood...from the junkyard.....if you manage to find a matching colour....it would be nice.
Headlight and side markers also from junkyard.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
