Vida 2014D Times out 12/31/2017 23:59 Topic is solved
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
Re: Vida 2014D Times out 12/31/2017 23:59
Yeah I tried reinstalling VIDA to no avail. The laptop in question (Samsung NPQ680Z5E) is a newer 'thin an light type' designed to compete with Macbooks but running MSW. A bit of a pita to switch out the internal drive and no optical drive bay.
- mrbrian200
It's going again. But I couldn't tell you what the issue was. I did a deeper cleaning: Removed all traces of VIDA, SQL server, Isoview, and even the DICE device driver. Then concurrent runs of registry cleaner which catches all sorts of registry entries left behind by the uninstall of the mentioned programs.
Previously I just tried uninstalling VIDA through programs and features, which worked once in the past. But not this time.
The only thing I didn't touch was .net 3.5.
I do still have vida on the older clunky dedicated (offline) laptop, it needs the 2099 patch applied but otherwise if an 'emergency' pops up it's probably the only machine/vida installation I should count on to work anytime-forever.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
I used "Uninstall a program" tool from Control Panel, and then freshly installed VIDA, then patch 2014D. After the VIDA Monitor turns green, the All-in-one launches fine. The interface shows VIDA 2014D at the login page -- all good from there.
PROBLEM: For Vehicle Profile 2013A XC90, AME, I'm able to access stuff under INFORMATION tab. But under REPAIR dropdown ENGINE > 219 - Auxiliary Belt Drive, etc, is missing, hence no instruction for removal and installing of drive belt, tensioner and idler. SEARCH for "Belt" pulls group 219, parts, diagram, etc.
- Do you see 219 in your VIDA 2014D?
- Can you share the Group 219 instruction?
TIA!
TIA!
xHeart
It is Accessory Drive Belt under TRANSMISSION, group 215.
- mrbrian200
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 35 times
- Been thanked: 41 times
Can VIDA be installed on Windows 10 Pro Operating System (64bit)? I tried installing 2014D but get this error
"The operating system on this computer is not supported. VIDA only supports Windows 7 Pro (32 bit and 64 bit)"
I've searched and tried installing for days with no luck. I tried that Red PAck link but it let me to Chinese Spam.
XC70Rider
For those with a windows 10 pro operating system read step 16B on this webpage
http://vidadice.blogspot.com/2017/11/in ... ws-10.html
XC70Rider wrote: ↑29 Nov 2018, 18:24 Can VIDA be installed on Windows 10 Pro Operating System (64bit)? I tried installing 2014D but get this error
- RickHaleParker
- Been thanked: 958 times
Chinese is a language not spam.
To download the Repack, you need to have a bittorrent client installed. Then click on the Magnetic link. For a bittorrent client, my recommendation is qBittorrent.
The link is still working. If you are looking at the page translated the line is:
Magnetic link: magnet:?xt=urn:btih:1b2995ac6b8926893e3dea41c01ce92208b19c8d
Untranslated : 磁力链接: magnet:?xt=urn:btih:1b2995ac6b8926893e3dea41c01ce92208b19c8d
Else manually add "magnet:?xt=urn:btih:1b2995ac6b8926893e3dea41c01ce92208b19c8d" to a bittorrent client as a link.
XC70Rider
I got VIDA installed now. I installed the patch but still won't accept ADMIN , 1, 2, 3, 4 as a username?
"Unknown error: Please contact your local helpdesk..."
Do the patch files get put into 'C:\VIDA\Patch' folder?
- RickHaleParker
When you run the patch destination folder should be c:\
