Will a '98 angle gear fit my '99 V70XC?
jvl
Year and Model: 2006 V70 2.4D
Has thanked: 20 times
Been thanked: 8 times
Post by jvl »
I have a '99 V70XC, it has 200k miles.
The bevel gear whines. Changing the oil didn't help. I don't know the current part number. Where is it located?
Located a good used angle gear for a reasonable price, but it's from a 1998 V70 awd. That part number is P9183972.
I know there's differences in flange sizes, and from what I've read they can be swapped, correct?
Are there any other differences?
My v70xc is a late '99 (VIN YV1LZ56K8Y2661331)
Thanks for any insights.
Joost
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
There is a VIN brake in mid 98', from which point on the AWD is the same as 99'.
I will try to dig that up, I know I have a document somewhere that describes this.
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
jvl
Post by jvl »
Thanks Dirk, that would be amazing!
850 LPT
Post by 850 LPT »
I can't find the information on the VIN break anymore.
But, the part number for a 98' -99' angle gear is 8602679. That is the one I bought from Volvo a few years ago for my late 98' V70XC. That car was manufactured AFTER the VIN break and it is shared with 99'. So this one would be a direct fit for yours.
I don't know about the one you saw from the 98' AWD. I suspect it might be one from before the VIN break and would not fit. I will keep digging for the VIN break, I know it's in my e-mails somewhere...
Hope this helps,
Dirk
jvl
Post by jvl »
Again, thanks much for looking this up, I will not proceed then unless I can get more certainty on the vin break.
This is all good info and helps me in my search.
Please let me know if you run into the e-mail about the vin break? The seller is parting out a car so I think I can get the VIN belonging to this angle gear from him.
850 LPT
Post by 850 LPT »
The last 6 digits in model year 98 must be higher than 465001. I gleaned this info from SS, you can read through this thread for more info:
https://forums.swedespeed.com/showthrea ... +VIN+break
Hope this helps,
Dirk
jvl
Post by jvl »
Great! Thanks!
Based on the info from the topic you linked to, I've asked the seller for the VIN number and a picture of the flange and hope it turns out to be the right angle gear.
Has thanked: 1505 times
Been thanked: 3818 times
Let’s put both part numbers and the VIN break info into this thread once done for searchability
( that’s a note to myself)
jvl
Post by jvl »
Yeah, I also like to close the loop on threads for future readers but I haven't heard from the seller yet.
Will keep you posted Steve!
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I was in that same situation a few years ago and may have documented that VIN break on one of my videos. I was given a VIN breat that was NOT correct. It was several hundred off. I did end up getting an angle gear that worked. My mechanic had to swap the cone over from one to the other.
