P2 T5 V70 Rescue
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
Has thanked: 1504 times
Been thanked: 3817 times
Re: P2 T5 V70 Rescue
How did you get a transponder for $120 , Mike? That’s a sweet price.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Transponder for $5 (just an example as I bought mine 2 years ago)
https://www.ebay.com.au/p/Car-Key-Trans ... /805266749
Replaced 3.8 L transmission fluid by doing drain and fill. Shift quality is markedly smoother. Used Nulon Full Synthetic Multi Vehicle Auto Trans Fluid
New crush washer on drain plug
Cost: $62
Replaced both front spring seats.
Pro Parts spring seats let me down after about 25,000kms
Cost: $70 AUD
New Bosch coil pack for cylinder no. 3
Cost $AUD85
Replaced the tired old engine support stay with a new one. I pressed a Pro Parts one in with a plastic external rim after taking almost an hour to cut out the original Volvo metal one.
Cost $15AUD
Hit 250,000 kms today.
Cylinder 3 misfire again; connectors secured with high tech "Coil Connector Secure" TM
251,774kms
New split tubing for main engine loom coming from fusebox.
Replaced engine oil & filter
Castrol Edge 10W 30 and Nulon 10W 40 mix at 2:1 both full synthetic. Volvo genuine filter.
No sludge found in filter housing
Reset SRL with Vida
Replaced heater core o rings. Remind me to leave this on my list for "most hated" chores for P2 cars. Due to mine being a Feb 00 build the heater core is not removable without removal of the dashboard so I was very lucky it was only the o rings that required replacement. Later built models have a differently sculpted evaporator box allowing easy removal. Working in tight spaces is not my favourite pastime.
