Is the car a turbo or non-turbo?
One point many have not mentioned is check the water temp sensor. There are load values at various temps and see if it is in the correct range. Also check the contacts there the sensor meets the connector by the power steering pump. The wires and connector disintegrate with time.
If it is a turbo, the cars can be reluctant to start when it get really cold as the turbo intercooler can freeze preventing air to pass through it.
1996 Volvo 850 will not start in cold
- Has thanked: 1843 times
- Been thanked: 1710 times
Re: 1996 Volvo 850 will not start in cold
VdubTheran
- Year and Model: 1996 850 sportswagon
Thank you guys for all the help! Its the 1996 850 sportswagon turbo trim
VdubTheran
P0137,p1310,p0301,p0304,p0300, cel, service light, tracs off light.
Running:Fuel system 1 status =OL ,
fs2s =... ,
calculated load value = .8 - 1.6% ,
engine coolant temp = 183*f +/- 10*f 199*f max ,
short term fuel trim - bank 1 = 0.0% , long term fuel trim - bank 1 = -1.6% ,
rpm 840/min ,
ignition timing advance for #1 cylinder = 3.5* - 4.5* ,
air flow rate from mafs = 0.4lb/min ,
absolute throttle position = 9.8% ,
o2 sensor output volts (b1-s1) 0.295 - 0.300 v ,
short term fuel trim (b1-s1) 0.0% ,
all from datastream
I hope this helps you guys out. I know that there are alot of things wrong with my car but it gets my family of 6 around town for now. I want to fix it if its within my budget. I absolutely love this car! Even if my wife replaces it, i wont let it go.
fs2s =... ,
rpm 840/min ,
all from datastream
VdubTheran
I looked at the etc, long fuel trim 1, shrtf1, rpm on graph
ETC max 217, min 199 up and down climbing up slowly and dropping
LongFT1 stays at -1.6%
Shrtft1 stays at 0.0%
Rpm max 920 min 840 /min
VdubTheran
I will check it out it the morning, it will be colder tomorrow. After starting it in the morning it will start up like clock work the rest of the day.
VdubTheran
P0137, p1310, p0301, p1310, p0301,p0304, p0300, p0304
Datastream
Fuel system 1 status/OL
Fuel system 2 status/...
Calculated LOAD value/0.4%
Engine Coolant Temp./30*F
Short term fuel trim Bank 1/0.0%
Long term fuel trim Bank 1/-1.6%
Engine RPM
Vehicle speed
Ignition timing advance #1 cylinder/63.5*
Air flow rate from mafs./0.0lb/min
Absolute throttle position/9.8%
O2 sensor output v(b1-s1)/0.655v
Short term fuel trim(b1-s1)0.0%
No start cold
Datastream
Engine RPM
Vehicle speed
No start cold
VdubTheran
Sorry about the late response. I forgot to submit it
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Well... o2 sensor codes and a lot of misfires usually points to a vacuum leak somewhere. The ECT is a little confusing as well - was the first data stream from a warm engine?
Have you had any work done on it, like PCV replacement, etc?
Next time, unplug the MAF before starting, then try to start it.
Clear your codes, and read them again after driving some miles, to see what comes back and are “legitimate”.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
VdubTheran
Yes the car was already started that day and i did a running datastream. Yes two years ago i had a shop replace pcv system, and had to replace radiator a few months ago after sister in law ran over a 30lb raccoon, also replaced turbo rubber piping and vacuum lines in the front and driver side except one that was braided it looked good and i didnt have a replacement for it plus air filter. Cold start issue started about a month after fixing issues with racoon wreak. Plus no start with maf unplugged, it was one of the first things i tried. Could it have something to do with the emission pump it front of the throttle body, i hear it running in between cranking and after.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
This sounds very similar to when my coolant temp sensor failed. If you've had a thermostat fail or the car takes a long time to warm up, it's likely this went out too.VdubTheran wrote: ↑08 Jan 2019, 09:41 I'm having a similar problem with my 96 Volvo sports wagon Turbo. And I've read a lot of the forums on the cold start subject matter and I really don't know what I need to replace. I'm trying to find out what I can do to fix the car in the cheapest method possible. my issues are at 32 degrees the car will start after cranking and cranking and cranking and cranking and cranking and cranking and cranking. At 52 degrees i only need to crank about 3 times. I keep the car hooked up to a donor car while cranking to keep the rpms up and the batt charged. I crank the starter for 30 seconds plus each time. Im also having issues accelerating, it boggs down when i push down on the accelerator. I replaced all vacuum lines for the turbo. Ive had issues with the front fuel pump relay, but ive secured the pins on it. The fuel pump was replaced. This is drivin me nuts, and im ready to replace the car. I just need help finding out what to do.
'98 S70 T5
2016 Chevy Cruze Premier
