Pothole = Car shakes when in 4th gear?
jakethesnake
Year and Model: 1996 850 Turbo Wagon
Has thanked: 2 times
Post by jakethesnake »
Hey,
I had my gf pick me up from the airport last week and on the way she hit a nasty pothole on the freeway, going like 70mph. She said she heard a loud mechanical clunk and now my poor 96 850 turbo wagon (auto transmission) wobbles when it's in 4th gear, but only when i'm gassing it or when gear is winding down. When it's kept at a constant speed it's smooth as hell. Also gears 1-3 are running perfect, but once I hit 4th gear the entire car shakes.
No signs of a bent rim, so I'm thinking cv axle or transmission.
Any ideas?
Jake
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Check your Strut mounts.
1. Open hood.
2. Stand on the side of car.
3. Grab underside of fender.
4. Fix your eyes on the top of the Struts.
5. Lift up on the car.
Are the Struts moving around in the Strut mount?
Active
Past
jakethesnake
RickHaleParker wrote: 22 Jan 2019, 00:14 Check your Strut mounts.
1. Open hood.
The cap of the strut on the driver side rotated (seems loose) as I lifted. The pothole was hit on the passenger side, so I believe this is a separate problem.
It feels more like transmission, because the shaking only occurs in 4th gear.
jvl
Year and Model: 2006 V70 2.4D
Has thanked: 20 times
Been thanked: 8 times
Post by jvl »
I once hit a nasty ridge on the front right side at 70 kph, the car started vibrating as well. It also started drifting to the right, the alignment was totally off.
Not sure whether it was gear-related.
This is what I fixed to get rid of the vibration:
- new lower right engine mount (I think it was already bad and this was a final blow)
- had front left and right driveaxles replaced for used OEM at indy
- replaced both controlarms
- had new outer tie rods installed at indy + alginment
Hope this helps. I think many parts in this list were already old and this was just the final blow.
Check the lower right engine mount and control arm bushings for play first.
Good luck!
Joost
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
Been thanked: 4071 times
Could the 4th gear vibration be a consequence of the torque converter locking up and then transmitting vibration to the frame?
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
if it were the torque converter, it would most probably not be felt when speeding up because then the converter won't lock up.
1996 855 R,
2010 V70 D5,
