Got these new, yes new, control arms on Rockauto to try and solve a swerving issue i had on wifes XC90. Did both sides. The swerving was not fixed, stumped i started looking into other things and today decided to just put a camera under there and here what i saw.
I'll be buyin a new set of Meyle HD's from IPD
GoPro on a low quality control arm
Masscomguru
- Year and Model: 2010 XC90 V8
- Been thanked: 16 times
That’s insane. It’s almost criminal that these are being sold...
terryjr
- Year and Model: 06 XC90 - 04 XC70
this thing has been such a pain, and now my xc70 is gettin issues.
06' XC90:
-AWD only works when its freezing outside, and usually only works for a few miles. Will work again after an ignition restart.
-the obvious swerving issue
-CD player makes god awful noises every time you start it for about 30 seconds
-oil leaks horribly, but stopped recently. either quakerstate high mileage works or its just out of oil
-both front windows now go back down after they fully close when using the auto up
-ac has a leak, full charges last 4-6 weeks
-exhaust and turbo coolant lines could crumbled at any time
04' XC70:
-AWD doesn't work at all. I have a ABS-0022 right front sensor code. too cold to investigate lately
-front rotors are pretty much done, will check out that abs-0022 while im in there
-pcv is completely clogged, hated that job on the 90, dragging my feet to do it again
-burns oil or something, does not leak but goes through a gallon a month with no smoke
-cant lock tailgate or use rear wiper because the new one i got when window broke is wired backwards. that was funny when i used wiper and i swiped the license plate
-only 2 coil packs left to change, love when those go, because its usually at the end of work day before 25 mile drive home
-seat heater quit
-been through 3 window washer pumps
Other than those things they have bee great i guess. Combined 342k miles
06' XC90:
04' XC70:
-seat heater quit
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
Wow, that's impressive. Thank you for sharing!
FYI, I have had really poor results with Meyle. On my XC90, I replaced them after ~10k miles. Some people like Lemforder, but I will only put on blue-box volvo control arms now. I'm tired of doing it again in short order, and the blue-box Volvo ones have lasted me a decent time. (Up to 42k miles now, and still performing well.)
Roger
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
- Year and Model: Lots
- Been thanked: 128 times
The arms are probably OK if you press out the bad bushings and press OEM or Genuine bushings in their place.
I had squishy genuine bushings on our newly acquired 2006 XC90. Visually they looked fine. Mind you they were at least the 2nd set by 100K miles as they had yellow alignment marks painted on for fitment. XC90s chew through front bushings even when genuine.
They made the steering dart to the right under brakes. All good since I pressed in some new bushings.
- Roger_850T
This video makes the solid polyurethane look appealing... Maybe even Delrin in the front...
Roger
Roger
11 XC60 137k
05 XC90 V8 213k
05 XC90 V8 213k
Justtellme
- Year and Model: 2010xc90 1991 780
- Been thanked: 3 times
That video is a bit scary.....
The window problem is easily fixed. Just need to reset them.
Open the fuse box in drivers door, locate the fuse for each door window and do them individually.
Auto down each window and while it is in motion, pull out the fuse before it hits bottom of travel.
Then replace fuse and open and close the window ar least two full cycyles of up and down.
Note that auto down and up functions will no longer work until you complete the two cycles.
This procedure resets the upper and lower stop limits for the auto window function.
Should work fine after this procedure.
The window bouncing back down on auto up function drove me crazy till I did the reset.
Patrick
Patrick
terryjr wrote: 28 Jan 2019, 13:34 this thing has been such a pain, and now my xc70 is gettin issues.
06' XC90:
04' XC70:
-seat heater quit
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Nice video. As mentioned, skip the Meyle HD. Maybe get the Ipd HD but again, it's risky. Lemforder should be better or if the car stays longer, OEM. As I was saying in a video, the amount of rubber doesn't matter on suspension parts, if the rubber quality is cheap - note that all rubbers look the same but the composition can differ enormously. Producing a rubber compound that lasts is an art and comes with a price.
- 10 Replies
- 3869 Views
Last post by WhatAmIDoing
- 13333 Views
Last post by MarcM
- 2966 Views
Last post by 800artfreed
- 2507 Views
Last post by Volvo Kush
- 11 Replies
- 5302 Views
Last post by mrbrian200
