1999 V70 T5 - Broken Hatch wires lead to no-crank condition, Manual trans 9168056
This topic is in the MVS Volvo Repair Database » How To Troubleshoot Volvos
mnorris23
Year and Model: 2000 S70 2.4l GLT
Post by mnorris23 »
abscate wrote:Follow up on this. The clutch throw required definitely went up, and today.....cruise control went out.
Also, hit a bump on the pike and ABS light came on...I'll bet my rear right ABS sensor wire fix gave out.
Checking....
What kind of leak is that code referring to?
Car I own: 2000 Volvo S70 GLT 130k Stock with OEM replaced parts.
Been thanked: 4065 times
Evap leak. Takes 1500-2000 miles to light CEL on average.
The other two are clutch switch errors, now gone.
Added what is believed yo be part number or replacement wiring harness to thread
About $175 for this part currently. 9168056
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
So, what does one do at this magical bypass point? Ground it and turn the key? Connect it to 12v and turn the key? Connect it anywhere and jump back? ;-) Howzit function? ;-)
All U.S. market models.
All running and on the road.
When you put 12V on it, the starter will spin and engage the motor.
You have to be careful with it as all safety functions are bypassed. A manual transmission car will run you over.
