Don't know what it was about this puller that inspired confidence. But after a little back and forth (and installing this thing wrong a few times) I was able to pull the pulley off. This was off a 95 850 so the pulley was wedged on there for over twenty years!! It was $50 though... I will have to replace my brother's power steering pump one day... and he's got two P80s so maybe it'll pay for itself?
Here's a link to the product that makes use of the MVS referral link.
https://www.amazon.com/Lisle-39000-Pull ... dpSrc=srch
The definitive P80 Power Steering Pump Pulley Tool: Lisle 39000
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 36 times
Retired:
2015 Volvo S60, T5, 85K
- clarkerussell
- Has thanked: 20 times
- Been thanked: 4 times
100% agree with this, the tool is awesome and THANK YOU @theWIFES_S70 for the tip!theWIFES_S70 wrote: ↑16 Nov 2017, 22:16 Don't know what it was about this puller that inspired confidence. But after a little back and forth (and installing this thing wrong a few times) I was able to pull the pulley off. This was off a 95 850 so the pulley was wedged on there for over twenty years!! It was $50 though... I will have to replace my brother's power steering pump one day... and he's got two P80s so maybe it'll pay for itself?
- Has thanked: 1500 times
- Been thanked: 3812 times
For removing part 1397645
Power steering pump pulley -1998
1999 o;pulley unbolted but it’s a junkyard search for that pulley, NLA from Volvo
You can get replacement composite pulley by DORMAN 300-319
- theWIFES_S70
Glad it worked out! Love the build of old-school Lisle tools!clarkerussell wrote: ↑19 Feb 2019, 20:00 100% agree with this, the tool is awesome and THANK YOU @theWIFES_S70 for the tip!
Retired:
Bumped for Sven
sventastic
- Year and Model: 1996 854R
- Been thanked: 6 times
Thanks, I found this thread earlier (and another one with the same tool) but I was hoping someone else had used the tool that I can rent (this one for reference - https://www.partsource.ca/products/7703 ... -installer). Pretty pricey to buy either one unfortunately
The GM pump assembly in this video looks remarkably like the P80 pump, but it'll come down to whether the threads are compatible or not.
1996 854R | M56H | 16T | 274k | BC, Canada
- Has thanked: 1839 times
- Been thanked: 1709 times
Have you tried Princess Auto? Do you have one on the 'Island'. They may have an own brand tool. They also ship.
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
Anybody used the OTC 4530? It says 1-1/8", 1-1/4", 1-5/16" and 1-3/8". I just measured the hub on my pump and it's 1.165".
https://www.otctools.com/products/power ... ervice-set
sventastic
I used a 3 jaw puller to remove the pulley which was quite effortless. Made a loud 'pop' when it became unstuck from the shaft, then just had to thread it off. I threaded a 3/8-16 bolt into the shaft so that the puller didn't mar up the shaft. The diameter of the puller's shaft was also too large, so you need something to be proud of the pulley lip to press on. I had to unthread the bolt a couple of times as the pulley worked its way off the shaft
The reinstalling tool from OEM Tools kit that I originally inquired about worked great for putting the pulley on the new pump.
