2002 S60 2.5T P0017 after timing belt change
daverdfw
Year and Model: 2002 S60
Post by daverdfw »
So I changed the timing belt on the S60 this weekend. And got the p0017 crankshaft position sensor error. I took things back apart and double checked all the marks, they are all exactly lined up. Motor runs fine. I even tried to move the VVT came back a tooth as I have seen people say this resolves their issues. I still have it. Does anyone know how many teeth of the belt should be between the 2 marks on the cam gears?
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
On mine the cam sensor was loose, the one on the rear of the shaft.
daverdfw
Post by daverdfw »
jonesg wrote:On mine the cam sensor was loose, the one on the rear of the shaft.
i'm sure it has to do with me doing the timing belt. I should have marked the belt before taking it off, I just went with the factory marks.
jonesg
Post by jonesg »
Achhh, yes , you HAVE to use touch up paint to mark the cam sprockets Beforehand, especially if they have the CVVT setup.
You'll probably have to baseline it now.
jonesg
Post by jonesg »
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
If all you did was replace the belt (and possibly the tensioner), and you didn't disturb the sprockets/hubs attachment to the camshafts, then you can ignore all the talk about winding the hubs this way and that way, etc. Just get the three sprocket marks on target. See this video:
Note that he didn't even mention worrying about the VVT.
Since you're getting p0017 crankshaft position sensor error, my guess is that the cam sprockets are positioned properly in relation to each other and it's the crank that's a bit out of whack. If you move the belt one tooth on the crank sprocket, then it moves the crank one tooth (obviously). But if you move the belt one tooth on both cams, then it moves the crank 1/2 tooth.
jonesg
Post by jonesg »
could be the tensioner was set wrong.
daverdfw
Post by daverdfw »
It was the crank that was off somehow. I took the belt off and just manually lined up the 2 cam sprockets and the crank. Its been like 2 days and now errors or pending errors. thanks everyone!
mrbrian200
Been thanked: 84 times
Post by mrbrian200 »
daverdfw wrote:It was the crank that was off somehow.
I never felt confident about that timing mark on the crank. Illustrations showing various score/notches that may be present on different engines simply wasn't there on mine. There may have been a small notch on the inside of the gear toward the engine block but it was so subtle I was having trouble differentiating that tooth on the gear from the next. I had marked the crank pulley in relation to the RH engine mount with a drop of paint on each before I removed the original belt. I'm glad I did that.
Goldchemist
Year and Model: 2006 S60 2.5T AWD
Been thanked: 4 times
Post by Goldchemist »
I have a 2006 S60. The notches on my crank are so small I need to shine a light directly at the gear and stare while turning the crankshaft. I had the whole thing apart when I was changing the oil pump gasket and I looked for marks and didn't see them. They were there, I just didn't see em. No I know where they are and I can spot them like I said.
