Hello...
First time on this site. Thank you in advance.
I bought a used 1995 Volvo 850 turbo (2.3L turbo) I test drove it and it seemed really solid, started right up in the 15 degree air and drove surprisingly well for its age. No hesitation, no issues that were glaring. It has 200k Miles and was a one owner who had a huge list of maintenance done for the last 20 years. This guy had put another 20k back into this car over the years. I had about a 100 mile drive to get it home which was amazing till about 50 miles in when I noticed a little loss in power. I got off an exit and the car seemed to struggle to idle ... it didn't die but it struggled and has ever since. It starts, it runs but under load it shakes terribly in the front end... dash sounds like it will shake off. Once up to speed and cruising, there isn't an issue. I have changed the thermostat which was the one small issue I noticed and fixed the temp gauge. I have since had a tune up, new coil pack, and new motor mounts. Gas milage is a bit better but still the shaking in idle and getting up to speed. performance seems to be down as well... any ideas????
New to me 850 turbo sedan Topic is solved
dfellows77
- Year and Model: 1995 850 turbo sedan
- Has thanked: 6 times
- Ocelot
- Year and Model: 1998, S70
- Has thanked: 61 times
- Been thanked: 17 times
English isn't my native language, when you mention that you had a tune-up, did you also replace new plugs, cap and rotor? And I would certainly check for vacuum leaks (see youtube clip below).
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Recent car
dfellows77
yes a full tune up! plugs, wires, etc. I haven't checked the hoses. I will check this video out thank you!
dfellows77
ok... no vacuum leaks, injectors maybe?
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
More likely the fuel pump or fuel pump relay than injectors. Get a cheap tire gauge (will be destroyed unless you have a fuel pressure gauge) and check fuel pressure at the schrader valve after prime (before start), then at idle and report back.
Knows enough to be dangerous
dfellows77
will do...thanks
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
Fuel filter ?
dfellows77
haven't done anything with the fuel filter, pump or relay
- Has thanked: 292 times
- Been thanked: 765 times
Agree with all the comments so far. Jumper the fuel pump relay with a wire or paper clip. The symptoms will go away immediately if the relay is the problem.
If fuel supply seems to check out, consider cleaning the IAC (Idle Air Control) valve.
Any codes or CEL?
Any codes or CEL?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
