One other thing to check is the condition and tightness of the hoses to and from the intercooler. The car runs much as you describe if there is a loose hose or a hole in one of the hoses. The holes usually occur on the side of the hose where you can't see it without removing the hose from its connection point.
New to me 850 turbo sedan Topic is solved
- Year and Model: Many Volvos
- Been thanked: 75 times
Re: New to me 850 turbo sedan
dfellows77
- Year and Model: 1995 850 turbo sedan
- Has thanked: 6 times
Will check these all this week and check back. Thank you all.
dfellows77
Yes seems like it. Just had new plugs wired dist cap. Coolant is good
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Rguzz has a good point - if you’re missing a cylinder, it will often be rough at idle, seem smooth while cruising and then be rugged again under load, with loss of power. Check your codes and see if there are misfires. Check firing order and wires again for correct placement at both ends. Inspect plugs.
As for the movement, which I didn’t see anyone comment on - engine should move very little while you’re in a position to observe it. Check upper torque mount, and lower torque mount for wear and play. Front mount (i.e. passenger side engine mount is a known culprit as well. All these three are easy to replace, however.
Vacuum/boost leaks are super common on these cars, and probably account for 70% of weirdness, if not more. I’d put hoses and codes at the top of my list of things to check.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
dfellows77
Thanks for all the comments. Code is misfire calendar 1. With new plugs wires and coil. That leaves injector or head gasket
- Has thanked: 292 times
- Been thanked: 765 times
Or a burnt exhaust valve (check compression)
Or a leaky intake manifold gasket but that is usually at the cylinder 5 end
Also note the cylinder # report is not always accurate for misfires.
Did you swap the plugs around, it's not a bad plug in #1? What kind of plugs?
Are the wires Bougicord? Aftermarket wires are a big issue with these cars.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
dfellows77
I havent checked anything yet. I believe plugs are Bosch. I didnt check wire brand. I had that done at a shop. I will check
Bosch coppers should be fine but post up the plug number when you get to that.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
dfellows77
I will... somebody tell me these things are worth all of this...or maybe I should have gotten the used civic. haha
