What's fair price for a clean 2001 t5 wagon, ~ 140k miles?
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
re; rear shock, they dont do anything on the up, and dampen the down after the bump. basically they do nothing except keep the tire form oscillating up and down and reduce bounce.
- RickHaleParker
- Been thanked: 979 times
That is full retail for a fully loaded in clean condition. Private party transaction would be ~ $1600.
Trade in $900, Private party $1600, Dealer Retail: $2900.
Active
Past
Past
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
abscate says:
Also, what additional years around '01 have similar fitment parts?
Does the '01 have the pricey throttle control thing and fuel pump that requires tank drop?
What if the stop-neutral software is still installed and how could it be removed?abscate wrote: 03 Apr 2019, 17:31 If the AT shifts smoothly and the neutral stop software was removed its a great car at $1500
- Has thanked: 2857 times
- Been thanked: 1332 times
Hi Jim, here's 2001 Volvo transmissions guide page, with links off from it with loads of information. Short answer: if it still has stop-neutral, a dealer or VIDA can remove it.JimBee wrote: 03 Apr 2019, 21:38 What if the stop-neutral software is still installed and how could it be removed?
I'd say there's perhaps a small 5% incompatibility each year out from 2001, with a jump at 2004.
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
All of the 2001 V70 turbos have the problematic Magnetti-Marelli ETM. Only the V70XC (4WD)in 2001 has the split fuel tank which has to be dropped to replace the pump and as far as I can tell the T5's were all FWD.JimBee wrote: 03 Apr 2019, 21:38
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
- Has thanked: 311 times
- Been thanked: 817 times
T5 is tempting but I'd wait for an 04+, or a cheaper 01 with ETM and neutral stop fixed.
You are on Minneapolis roads I think? An 850 will always be jarring in that case, especially a wagon.
- Been thanked: 4068 times
If it’s gotta a yellow label on the throttle body it’s been done
If it’s white labeled ETM at 140k, it’s right at end of life. Budget $500 for that.
If it shifts fine , don’t worry about the AT
JimBee
Thanks all for the info. I'm ruminating on it.
Supposing that the car has good esthetics but hasn't been maintained or lacks records and needs a new ETM, what are the likely repairs going to add up to?
I'm thinking TB, water pump and roller kit, suspension parts, tires (no mention in ad), brakes. Would the buyer be looking at another $1,000 to $1500 in parts?
That would be worse case I think, Jim
Could easily be under $500
- gmh
A yellow labeled ETM is not a guarantee it doesn't need replacement, only that it has been replaced at least once.abscate wrote: 04 Apr 2019, 02:36 If it’s gotta a yellow label on the throttle body it’s been done
Have a look at this survey of people that did the XeMODeX replacement:
viewtopic.php?f=12&t=19102
Note the sticker color of the ETM they replaced.
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1969 145S (1987-91)
1973 145E (1989-90)
- 11 Replies
- 2219 Views
- 791 Views
Last post by callahanoffroad
- 2145 Views
Last post by alschnertz
- 15 Replies
- 3184 Views
Last post by bmdubya1198
- 992 Views
Last post by raquette
