I've always been told this. On Volvo below a certain temperature the automatic climate control wont run the compressor but in occasional short periods then below a lower temperature not at all. So you are saving no fuel saving by manually shutting the compressor off. At cool temperatures the compressor has no load anyway. So no real fuel benefit. It does however help keep the fog off the windows even when heat is being used. I understand Volvo recommends using the automatic climate control year round with the compressor kept active. June
Another AC post
- June
- Has thanked: 523 times
- Been thanked: 261 times
Re: Another AC post
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- RickHaleParker
- Been thanked: 958 times
Ever notice the A/C clutch engages for a few seconds every time you start the car?
That is done to keep the oil in the refrigerant from settling. The oil is what hermetically seals the refrigerant in. When the oil drains to the lowest point, from the car not being started for a long time, is when you get the leaks.
As long as you start the car periodically you don't need to worry about this issue. If you have a car that is not being used, start it up periodically to prevent this issue.
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 52 times
Well since we're on the subject I actually don't have ECC my current 850 is a '95 base, it has the complete manual suite with minimal amenities (so everything actually works on this one hahahaha). That being said I do not have ECC on this car and the AC compressor must be activated manually. So as a result the lights in my car just mean "on" or "off"
LOB
- Year and Model: 855 GLT 2.5T
- Has thanked: 10 times
- Been thanked: 16 times
Thanks, I didn't know that.RickHaleParker wrote: ↑09 Apr 2019, 07:00Ever notice the A/C clutch engages for a few seconds every time you start the car?
What really improves the longevity of the AC, at least in the "rust belt" of the northern hemisphere, is to rinse the AC condenser with water every time you've been driving on salted roads (it will also prevent the cooler and it's clamp hoses to corrode, preventing dire consequences). My AC is untouched since it came out in Gent in June 1996 except for a refill a couple of years ago and that's quite extraordinary driving on the salted roads of Sweden and Norway (actually my car was driving around Illinois the first couple of years, imported to Sweden by a swede expat, one advantage of having a speedometer in miles/h is that my wife never accuses me of speeding
- RickHaleParker
I came up with a weight diet that users are happy with. I change their scales to metric. They see lower numbers, they happy,, problem solved
- Has thanked: 1504 times
- Been thanked: 3817 times
Treat the MCC control unit like gold.
They cost $470 with core and you won't find them in PnP
- callahanoffroad
The guy I bought this car from basically said the same thing. I'm paraphrasing here but he said "I bought the most basic version of the 850 possible so that I'd have a vehicle that would never fail." Of course that doesn't dissuade me from wanting a fully loaded turbo with rear heat seaters...
