86' 740 fuel sender wiring Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Re: 86' 740 fuel sender wiring
Post by 93Regina »
Do you have a Turbo
for cars with plastic tank. cars with K-Jetronic (B23E,B200E,B230E,B19ET,B23ET). cars with or without extra tank
https://www.ersatzteile-wug.de/en/elekt ... -5537.html
stabworthy
Year and Model: volvo 86 740 gle
Post by stabworthy »
93Regina wrote: 04 Apr 2019, 20:53
stabworthy wrote: 04 Apr 2019, 16:29heads up looks like both amazon seller and the volvo of phoenix, are a bust
Both were the same....here is one, but it won't be cheap to be shipped from Europe
Not sure why you need one...if fuel pump works...you don't need a fuel gauge. On one 240, fuel gauge works once in awhile, and on one 940, it never works. I've done this for years....never run out of fuel so far.
I have no idea if more than one version existed stateside. Does your existing pump have a Volvo part number?
a bit pricey for my blood. i have a new pump, the old fuel pump is shot and the PO messed up the sender (we think that is why he never fixed the car). the wires are all crusty and somehow the part that goes though the sender top was ripped out .
I'm in the process of just rewiring the old one. from what i can tell the fuel gauge side works.
93Regina
Post by 93Regina »
stabworthy wrote: 05 Apr 2019, 18:48a bit pricey for my blood.
Another red blocker neglected to replace ground wire....he was some 500 miles from home, and his 740 would not start...towed it back, and found out ground wire had fizzled out. It takes two wires...hot and ground.
On my 940, I figured someone replaced the pump since it has over 1/4 million miles...either dash gauge or sender unit is the issue, but I'm in no hurry to fix it. Its got a 20 gallon tank....
If you have NA, then higher pressure pump is needed....if you have a Turbo with K-Jet, then a lower pressure pump will be used
waynegarbo
Year and Model: 86' 740 non-turbo
Has thanked: 2 times
Post by waynegarbo »
Stabworthy, I also have out used and re-wired mine so much, I had to go and get another one our of that 87'.
