850 NA cylinder head interchange - what will work?
ollen001
Year and Model: Volvo 850 GLT 1995
Post by ollen001 »
Not a frequent poster but an absolute frequent reader of MVS posts. I have been unable to find definitive advice for naturally aspirated cylinder head interchange. This is a request for advice and hopefully, actual definitive answer.
I need a cylinder head for:
1995 Volvo 850 GLT (this year of GLT had no turbo as opposed to later years)
B5254FS
naturally aspirated, non turbo
NO air pump (that I can see)
this model has no OBDII (this was the changeover year)
five speed M56 gearbox
VIN: YV1LS5504S1226658
cylinder head has Volvo p/n 9146335
casting on top has number 1001664
My proposed donor head is from:
1998 V70
B5254S
automatic
VIN: YV1LW5548W2404109
cylinder head has Volvo p/n 9146337
casting on top has number 1001671
Will this head work?
If not, which Volvo p/n will work without modification (changing valves, etc)
Is it the casting number on top that is important, or the Volvo P/N?
Looking at the Volvo parts website, I get Volvo P/N 8111178 as cylinder head exchange that seems to fit both cars, however, I am assuming a rebuild service for Volvo just takes your head and gives you a head that will fit. Don't know if that p/n actually fits everything that they mention, meaning, it might just be a generic p/n used for exchange when you purchase that service. (I know, it is confusing to me, too.)
If anyone has lookup capability, I would appreciated the definitive answers you could give me.
Has thanked: 311 times
Been thanked: 817 times
Yes, the donor you propose will work perfectly.
More generally, all 20 valve, North American non-turbo 95-98 heads are identical, regardless of what the engine numbers are or what the books tell you. Swap it in.
I'd replace the valve stem seals on the donor head, they are often bad by this point. Volvo only on that part.
ollen001
Post by ollen001 »
Wow! That was quick!
Also, you can do mind reading. Because it's basically only valve stem seals that I need to replace at 132K miles.
Now, for the question which has been answered multiple ways on this forum and others:
Are OEM Volvo valve stem seals REALLY just Victor Reinz? The pictures don't seem to match, plus, the color is wrong, and, several people on various Volvo forums have said either Victor Reinz valve stem seals are the same thing, or, that they fail and Volvo OEM is the only way to go. I note that Elring, MTS, Ajusa, Victor Reinze, Mahle and other vendors offer them.
This head is going out to a professional rebuilder so that I have it on hand when we do the head (and get it out of my garage!) and we don't have to wait for it be be rebuilt. The spare head will go on the shelf, since, yes, at 132K miles, this was a gift car from a friend whose mechanic told her "You need a new engine since it's smoking". That was 15K miles ago. Did the EGR flame trap kit and renewed plugs, cap, rotor, plug wires, cam, crank, temp sensors plus all new everything else so I plan on keeping the car.
If I'm going to replace the valve stem seals, I need to know, from experience, should I really spend $135 on Volvo OEM or are Victor Reinz really the same thing?
Same question for cylinder head gasket? Volvo OEM or Victor Reinz?
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
OEM head gasket only. If the Volvo seals are too expensive, then go with Reinz. If they fail in 100K miles, then replacing them is not a head removal option.
Klaus
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
I gotta jump in here, if your '95 has VVIS like mine you'll have to replace the intake manifold with a later manifold. The intake ports are shaped differently. I only add this as you also have a manual transmission, no air pump, and no obd2. But otherwise you should be fine. I've had to do a bunch of research myself before I rebuild my head.
The heads are compatible, but the intake manifolds are not.
As per callahan the safest bet is to get the intake manifold with the head. Or if you can't, I have a spare that matches the 98 head and will be driving to MPLS on April 27.
I agree with Klausc, head gasket is Volvo only.
Good news, full kit of Volvo branded valve stem seals is $76 plus shipping: https://parts.volvocarslisle.com/p/Volv ... 72424.html . Or get a price on Volvo 272424 at your local dealer (see viewtopic.php?t=71962).
