Left turn signal doesn’t go on at all outside but blinks rapidly inside. Left hazard also does not work but inside both blink at the same time and pace. When I turn on the left turn signal a left turn signal bulb failure warning comes on. I’ve checked the lights but they’re not burnt. Including the one in the center.
I’ve checked the CEM but the shunts seem to be working fine. I switched them around and none seemed to solve the issue.
All fuses are fine
Any help would be much appreciated I’ve put in lots of time and effort into this.
2001 Volvo S60 Turn signal issue Topic is solved
Alexis2929
- Year and Model: 2001 S60
- Has thanked: 6 times
It's got to be a bulb somewhere...or a bad connection in the rear tail light assy. In the old days ( the 90's) most cars have a thing called a flasher... make the signal flash. I don't know if a 2001 Volvo has that set up...MDK
- Been thanked: 466 times
Probably bad contacts inside the turn signal stalk.
Search for the DIY, where you remove the stalk (two Torx bolts), and clean the contacts with fine sand paper. Then add a bit if grease.
It is a FREE fix.
It is a FREE fix.
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 44 times
I'll offer a few hints to hopefully help with your troubleshooting.
You say the bulbs in question on the left side are good. Have you moved them to the right side to see if they work? Have you moved the bulbs from the right side to the left to see if they work? This could help eliminate if it is one of your bulbs. If left side works in the right side, and right side does not work in left side, your issue is elsewhere (socket, stalk, wiring, relay, etc.). Try one bulb at a time, starting with the front bulbs.
Volvo's are very sensitive with the bulbs you use. I've also had "good" bulbs that didn't work. I've learned to only use high quality bulbs, mainly Sylvania/Osram and hopefully manufactured in Germany. They may cost a little more but work well and last longer.
I suspect you have a bulb or socket issue. Share your results. Good luck troubleshooting.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As above, I would venture removing the bulbs and look for corrosion or for a slightly broken bulb filament www.youtube.com/watch?v=Aq0V_anGtUw
You can also undo the stalk and maybe try replacing with used one from 01-03, but I would rather bet on the bulb sockets in the first place www.youtube.com/watch?v=gCSbTSj1THI
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 78 times
Don’t assume a bulb is good by just looking at the filament. They often break down within the base where you can’t see the problem. If the metal bulb base is at all loose on the glass part then toss it.
Alexis2929
I’ve moved the bulbs from left to right and still nothing on the left turn signal.
I looked into the CEM and there is no power on the left turn signal shunt
This would ecplain why my hazards also don’t work but could s bad ground not give power to the CEM ?
Or does the CEM distribute it.
93SCMax
So you've eliminated the bulbs as the problem.
Original post said CEM and shunts were fine, even swapping shunts made no difference. Your last post says you have no power to the left turn signal shunt. So you are confident that you have no power and it is not the shunt for the left circuit?
I'd suspect the CEM, although my original thoughts were a bad socket or ground somewhere. Maybe someone with a strong electrical background on the CEM will chime in. If you have no power at the CEM with both the blinker and the hazards, then it shouldn't be the stalk.
- 789 Views
Last post by InsanitySpark
- 9 Replies
- 1533 Views
