Danonly55
Year and Model: 1996 850 sedan
Has thanked: 23 times
Been thanked: 4 times
Re: What did you do to your Volvo today? (now Sticky!!)
Post by Danonly55 »
Replaced the trans cooler line today, Next the PCV system.
2014 Ford 3.5L ecoboost XLT
1995 Volvo 850 wagon GLE
Life is tough, but it's tougher when your stupid'
" John Wayne
Has thanked: 1502 times
Been thanked: 3813 times
Danonly55 wrote: 16 Apr 2019, 06:17
bmdubya1198 wrote: 13 Apr 2019, 20:02 Wrapped up the PCV job on the R. I replaced the metal pipe to the PTC valve with some 5/8" oil compatible hose in order to help further relieve crankcase pressure. I'll be drilling out the PTC sometime soon to finish this upgrade.
Shouldn't be blowing out any seals now!
What is the PTC, I will be doing my PCV system soon and any upgrade tips would be great, My car is a 96 850 N/A
The PTC Nipple
The PTC (Positive Temperature Coefficient) Nipple is just a hole, or Orfice nipple , to use the Volvo term. Its often mistakenly called a valve as it has an electrical connection, but that is just a heating element to keep the sludge from condensing and blocking it. It is a valve in the sense that it regulates vacuum to the Positive Crankcase Ventilation system, but it does not open and close like most think of a valve.
It is often drilled out, when in fact it is a required cleaning maintenance item every 60k miles on a new car, and (my recommendation) 30k on an old Volvo.
The reaction to "Hey the PTC is clogged, lets drill it out" should be "Why didn't I clean this per schedule?"
No judging here.
Total teardown of PTC Nipple here...
viewtopic.php?f=1&t=68898
:D
Danonly55
Post by Danonly55 »
abscate wrote: 16 Apr 2019, 06:31
The PTC Nipple
No judging here.
:D
So in your opinion here , should I drill this out when I install my new PCV system ? My car has 147K on it. I just bought the car last june and it's just now starting to build pressure in the crank case. The glove test fills the glove slowly.
" John Wayne
Danonly55 wrote: 16 Apr 2019, 06:50
The PTC Nipple
No judging here.
:D
Worthy of Forum thread since opinions vary here.
See here...
viewtopic.php?f=1&t=89204&p=503665#p503665
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
abscate wrote: 16 Apr 2019, 06:31 The PTC Nipple
No judging here.
:D
That's correct, not actually a valve. It's open all the time.
The only reason I'd drill it out is to alleviate any more restriction. I upgraded to a 5/8" hose coming from the oil separator, so I figured I'd finish the job by enlarging the PTC.
Ocelot
Year and Model: 1998, S70
Has thanked: 61 times
Been thanked: 17 times
Post by Ocelot »
Yesterday I went to an AC specialist in my hometown Zwolle (Netherlands). Usally I fix everything myself, well, at least I try to do, but I'm not experienced with AC's nor do I have the tools/equipment to do it properly. The AC on my 1998 S70 didn't cool anymore, not at all. After an inspection my guy told me the condensor had a leak and the compressor needed some maintenance. I don't know how to say it in English, but the compressor has a clutch and the gap between the clutch and the compressor can get too big sometimes, you guys probably know what I mean. So, after paying a 500 dollar bill my S70 has icecold AC again :-) I also noticed that the S70 can run pretty economic. I went from Zwolle (Netherlands) to Bruges (Belgium) last weekend and I managed to get 12,8 kilometers per liter fuel (30,16 miles per gallon in US terms, 36,22 mpg in UK terms) so that really made me smile. Have a good Easter!
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
bmdubya1198
Ocelot wrote: 20 Apr 2019, 14:00 Yesterday I went to an AC specialist in my hometown Zwolle (Netherlands). Usally I fix everything myself, well, at least I try to do, but I'm not experienced with AC's nor do I have the tools/equipment to do it properly. The AC on my 1998 S70 didn't cool anymore, not at all. After an inspection my guy told me the condensor had a leak and the compressor needed some maintenance. I don't know how to say it in English, but the compressor has a clutch and the gap between the clutch and the compressor can get too big sometimes, you guys probably know what I mean. So, after paying a 500 dollar bill my S70 has icecold AC again :-) I also noticed that the S70 can run pretty economic. I went from Zwolle (Netherlands) to Bruges (Belgium) last weekend and I managed to get 12,8 kilometers per liter fuel (30,16 miles per gallon in US terms, 36,22 mpg in UK terms) so that really made me smile. Have a good Easter!
Happy Easter to you and everyone else here as well!
That's a pretty common problem with these cars. My cousin had a problem with that on his S70, the clutch was wobbling around and had a large gap. 30 MPG would be really nice, I get about 20 with my driving style around here. My R averages about 17-18, but I've been disconnecting the battery and doing lots of testing lately. I'm sure that will go up once I start driving it normally.
bmdubya1198
So I got the engine in the 850 freed up today! I was testing a few things that people were interested in if I parted it out, and I just turned the key for the heck of it. After the starter bumped a couple times and did nothing, I turned the key again and the engine started cranking and spraying Marvel like a geyser! Conveniently enough, we started tearing it down a little bit yesterday, but fortunately there wasn't a lot we removed. As soon as I was able to crank the car, I went an reassembled everything. It hasn't started yet, but I've confirmed it's getting fuel. I'll continue diagnostics tomorrow when it's not raining.
If I can get it running well, I'm going to fix it up. I didn't want to part it out in the first place just because it's lower mileage and is a clean rust-free chassis. According to the diagnostic connector, it only has 158k miles.
It’s been a good year for recovering stuck engines on rescues
Update on Elizabeth the 99T5
Repatched my two year exhaust leak
Cleaned all the oil off my new turbo line leak free engine
Adjusted parking brake
Measured front disks for new parts
Ocelot
Post by Ocelot »
bmdubya1198 wrote: 20 Apr 2019, 18:25
Keep in mind, I was driving with a speed of 110 km/h (±70 mph) and used the cruise control everywhere I could. I think it's a fun challenge driving cars as these Volvos as economic as you can (without bothering other drivers ofcourse).
Recent car
