DIY Wheel Alignment
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
Hello folks, With three cars to work on. What would be the practical method to do wheel alignments?
- Pay for the service on all cars?
- Use home made contraption (magnet, rope, etc)?
- Buy a cheep alignment tool kit?
Thanks.
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
couple of thoughts.. You cant really get a good alignment done if you go to any of the shops like STS tire etc. that pay by the job flat rate. an older car will have frozen end links and they will just hand it back to you the same as before with a bill. The only thing that can be adjusted is toe in. You can get pretty close sighting down the front tire to a half inch stick set against the rear wheel. then do the same but opposite turns each side to center the steering wheel. The main problem is not having turntables under the front tires to allow the steering to relax into rolling position.
I payed 800 for a snap on optical alignment system from the 80's. I have seen them much cheaper. Its something like WA95.
finicky and dont know if bulbs are still available but very accurate. The turntables are the expensive part since racers use them for set up. You have to have a dark garage to see the marks. wish it had a laser. It doesn't get used much, twice in 10 years so that 400 per alignment. If I had used it 6 times it would have paid for itself. It does take up some space and you really need a lift to use the stools that come with it, but you could just work on the floor though its hard to get at the end links.
Been thanked: 504 times
Post by cn90 »
Tricks...
- Remove the wheels and spray PB Blaster on the frozen nuts. Then use Propane Torch to heat the frozen nuts. Then loosen the nuts first.
- Re-install the wheels.
- Search forum for the DIY I posted. Basically:
* Flat garage floor.
* Straight Edge + Carpenter Square.
* Plumb Bob + String.
* Masking Tape on garage floor.
The important thing is the difference between the fore and aft parts of the tires.
This is just basic high-school geometry.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I've been doing the front geometry myself for the past 15 years. Considering my tires have uniform wear, I guess I'm doing it fine.
It is very easy actually, seems a little rough, but it works - at least for me. There is two things I'm looking for: have the front wheels parallel, and have the steering wheel centered while driving. It may take a few tie rod adjustments and then drives to have all these correct.
These are older videos, less well filmed, but they explain a little how I work
I'm not sure if I mention in the videos, but if the nut is stuck, can use a long pry par put on the subframe and pressing on the wrench, to loosen the nut. I usually tighten these nuts not too much, so it's easier to undo the next time.
As for the camber at the strut upper bolt, I usually set the most positive camber and forget it. I haven't seen any clear differences changing this camber setting
Side note: I started doing this after being cheated by three garages who in fact never touched the geometry because a nut was seized
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
I haven’t paid for a “professional” alignment in almost 30 years. The tape measure between the fronts of the wheels vs the trailing side of the wheels has given me the desired toe. Haven’t messed with camber too much but I’m considering making some sort of squaring tool that uses the garage floor as a reference plane.
Been thanked: 4065 times
If you steer fine, and the wheel returns cleanly, leave camber alone. Its definitely a DFWI if the car handles well.
oragex
Post by oragex »
Wanted to add, after hitting a pothole/curb/cat, usually having the steering wheel slightly turned to either side when going straight on highway, it's a good indication the geometry needs be done.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
cn90 wrote: 03 May 2019, 06:39 - Search forum for the DIY I posted.
CN90's DIY at home alignment
Also -> Amazon link
Rocket999
Year and Model: 2000 V70 XC
Post by Rocket999 »
cn90 wrote: 03 May 2019, 06:39 Tricks...
you mean level garage floor, and flat
