I am seriously considering purchasing a 1998 S 70 non-turbo station wagon for $400.
“Believe to be blown head gasket but still runs.”
Best case scenario, I get it running for my daughter. Worst case scenario, I scrap it and pull all the parts off of it I can.
Definitely the tires and rims make it worth the effort for me, but how do I find out about things like brake parts, interior, etc. for compatibility?
Parts to pull off a 98 non-turbo wagon for a 2000 S70 turbo Topic is solved
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 73 times
Most interior and cosmetic stuff should be the same. The 98s are different than the 99-00 models though with a decent amount of the mechanical/electronic stuff. As far as checking compatibility, personally I'd hit up a couple of the big parts websites and start comparing part numbers for 98 vs 2000 for the stuff you want.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Has thanked: 1502 times
- Been thanked: 3813 times
Most every bolt off part changed between 98 and the 99-00 " bastards"
For example
AC compressor
Alternator
Power steering pump
Coil(s)
Distributor
All different.
Don't use eBay as guidance for parts value, they are 3-5x overpriced, or worse.
I made a lot on a parts car but the stars aligned and I sold all the big , heavy non-shippable items in week one.
For example
AC compressor
Alternator
Power steering pump
Coil(s)
Distributor
All different.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Mechanical wise, I believe brakes, hub, and axles, are the same between 98 and 2000.
If you decide to part it, pm me. There's some parts I've been looking for for far too long now.
Knows enough to be dangerous
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
I don't believe the axles are the same. At least they weren't between a 98 manual s70 and my 99 manual s70.
the 98 used the big nut at the end of the axle. My 99 used the a bolt. Totally different. That was true on manuals at least.
- Has thanked: 292 times
- Been thanked: 765 times
Hubs and axles are definitely different between 98 and 00, will not swap at all.
Almost all interior is the same (although wagon and sedan have different rear seats), brake parts all the same, wheels the same. Not much else swaps.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- WhatAmIDoing
I could have sworn last I looked it up when parting a 99, 98 through 00 autos used the same axles. But that was based off a parts site and I suppose they are not always right.
-1998 reusable 36 mm castle nut
1999- on M8 14mm torque to yield , single use axle bolt with flange. No idea I feel the splines are the same and it’s just the hold would work, but I doubt it,
- 2049 Views
- 550 Views
Last post by SuperHerman
