Moved the crankshaft pulley
DRN2001
Year and Model: 2007 XC70
Has thanked: 6 times
Post by DRN2001 »
Hi Folks
I moved the crank pulley trying to remove it when I thought I had to do so when changing the timing belt: well, I worked out I didn’t have to so put it back on the mark and put the new belt on. All the marks line up and I’ve turned the engine over with a ratchet. Seems okay. Probably a dumb question but d could I have screwed up the timing even if the marks are okay?
Cheers!
Has thanked: 1498 times
Been thanked: 3810 times
You are okay of the marks line up, not To worry
DRN2001
Post by DRN2001 »
Thank you, that’s a relief! I’ve always tried to buy cars that have timing chains - this was my first go at changing a belt!
