1995 into 1999 engine swap thread , Mike 2012
1999+ Head on a 1993-1998 Block?
- Has thanked: 2652 times
- Been thanked: 1240 times
Re: Correct compression testing procedure
Thanks for closing. I remember the t-bone.
- Year and Model: Lots
- Been thanked: 128 times
It was more of a fender-boning but when the opposite corner of the car's panel margins double it might as well have been a T
Still life treats me well....this week I get to eat food from my next door neighbour's bin as they're away on holidays
sou do brasil alguem pode me ajudar,preciso saber quanto de quilos é o aperto do cabeçote do volvo 850 turbo ano 94/95,e se alguel tem os esquema de ligar as mangueirinhas que sao do vacuo que vai na turbina ,se alguel puder me ajudar muito obrigado.
sou novo gostei muito deste forum mas nao estou sabendo usar me desculpe.
[email protected]
[email protected]
- Has thanked: 1498 times
- Been thanked: 3810 times
Retitled to document the engine swap
Life was harsh on this one, a masterful swap that ended up at the wreckers one month after completion
Brutal.
Hopefully someone who knows Port. Answered the cylinder head weight question and turbo line diagram ( I think ) above
Brutal.
jjss70
- Year and Model: 99 s70 Turbo AWD
- Has thanked: 7 times
Hi, I should have found the Matthews Forum a month earlier and it would have been less work at least. I have done the same swap as you have except that the 95 motor is also turbo and that along w/ the vvt on the exhaust cam adds up to after a month and a half of messing with it I register to a forum called Matthews and I read a reply to a question I submit and I find the reason why my car still runs like crap. I think I need a 95 cylinder head on the 95 block that is naturally aspirated which will come w/o vvt. If you would be so kind to reply, I would be ever so grateful and thanks so much for your write-up. Very inspirational. Thanks, so much. jjss70.
If both cars (donor and recipient) are turbo there is another issue; not the cylinder head. You need to stick with the 1999 head. Check compression readings and report back in.
jjss70
I only have the one 1999 S70 AWD Turbo w/ its original 1999 engine which has a cracked block in 3 adjacent cylinders and I had a friend w/ a wrecked 1995 850 Turbo Wagon and so I bought the motor from him and the compression readings were good dry, all around 165 & 170 psi. I do still have the original engine and head which did run after I sealed up the blown head gasket. I must say that, even though oil was accumulating in the radiator and 3 cylinders had sleeves that were riddled w/ cracks and only running on 4 cylinders, it still ran so much better than it does now w/ the 1995 engine installed.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
But... is it turbo or NA? And what do you mean it runs poor? Also, if you swap in the entire engine, why would you keep the ‘99 head?
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
jjss70
Both engines are turbo and I took the 99 head into the machine shop to get pressure tested for cracks and I will get info Monday or Tuesday. Also, what name brand of head gasket and head bolts should I get aftermarket? Thanks to guys on the Matthews Forum, you've all showed me the errors of my ways. So again, THANK YOU ALL.
