My new invention? Anti-stress safety for automatic transmission vehicles.
george90
Year and Model: 1996 850
Post by george90 »
Hello to everyone.
I have an invention to avoid pressing the accelerator pedal instead of pressing the brake pedal in case of stress while driving. I thınk it can be solved by pressure sensors placed on the steering wheel. When you squeeze the steering, the accelerator pedal is automatically deactivated.
What do you think of my idea? :D
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
already on my way to trademark bureau.
DeadEric
Year and Model: 1996 850 Turbo
Has thanked: 2 times
Been thanked: 12 times
Post by DeadEric »
When my son was 5 he climb into a Little Tikes Cozy Coupe and immediately started honking the horn and yelling "son of a b*#ch."
It was then that I realized my wife was right and I have road rage issues.
Having never been a stering wheel gripper, maybe add some sort of voice pattern recognition to it as well.
george90
Post by george90 »
"My invention calculates how much you squeeze the steering wheel with the pressure sensors placed on the steering wheel."
"If you squeeze the steering wheel for a long time while driving, your driving is usually not safe for the drivers and other drivers."
"Only drivers who are unable to drive or under stress can accidentally step on the accelerator pedal."
"This system prevents the driver from depressing the accelerator pedal when angry. The driver can be warned on the vehicle display."
"If the driver gets nervous in the car, he can't move the vehicle until he calms down, because the vehicle display constantly warns the driver."
"If you are angry, you are probably squeezing the vehicle's steering wheel. My invention is active now and the vehicle does not move even when the accelerator pedal is pressed. Example: You are angry with the driver and his friend in the car. The vehicle does not then accelerate. Danger lights turn on automatically."
"The vehicle does not slow down. Stops The accelerator pedal is deactivated. You cannot move the vehicle without stopping again. If you are still calm, then you can continue. If you are still nervous, you will probably continue to squeezing the steering wheel. You can only continue when it calms down."
"The driver is warns three times. Then it is activated. You cannot drive faster than 2 km / h. This speed is enough to draw you to the side of the road."
"First Warning: Squeeze the steering wheel for 3 seconds.(You will be alerted during this time.) Accelerator pedal is deactivated now. Second warning: Squeeze the steering wheel for 3 seconds.(You will be alerted during this time.) Accelerator pedal is deactivated. If you do not leave it your foot, the accelerator pedal does not start to work again, it repeats the countdown in the display (3 ... 2 ... 1 ... And drive...) Third Warning: Squeeze the steering wheel for 3 seconds.(You will be warned during this time.) The accelerator pedal is disabled. The accelerator pedal will not be reactivated until the indicator reads 0 km / h. "
Does this system confuse me on the road?
You don't get confused, because:
1. "Anti-stress safety enabled." This will appear on the display and the system will not turn on unless you squeezing the steering wheel for three seconds.
2. During this time, the driver is alerted to audio and screen. Example: If you stop pressing after 2 seconds, it will not be activated.
3. If you do not lift the your foot off the accelerator pedal, the timer will not start and if you press the accelerator pedal again within three seconds, the countdown will be canceled. If you take your foot off the driving pedal, the countdown begins.
In addition, my invention can also prevent your vehicle from being driven by an animal. :D
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Naa ... Fix the problem at the root cause, get the idiots and A-holes off the road ... driving permit revoked.
Has thanked: 1507 times
Been thanked: 3822 times
Tesla has a new tool for anger management detected during driving...
