LH 2.0 surging idle
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
kcteun
Year and Model: P1800S 1965
LH 2.0 surging idle
Post by kcteun »
1984 245 with 2.3 L and MT. It very suddenly started surging at idle and then dying at every stop when warm. I have done many things to isolate this issue and ran into a dark corner. When I check the voltage at the IAC valve while the engine is running, I get 13v at term 2-3. My understanding is, when the throttle switch opens, that voltage should drop to zero, and I should get 13v at 1-2. The voltage on mine does not change when the throttle switch opens. The throttle switch is properly adjusted and continuity checks out ok. The IAC is new, but it is a cheap generic part. I pulled the FI ECU and opened it up to look for burnt transistors or obvious faults. I have tested the AMM, O2 sensor, temp sensor. Replaced distributor, cap, plugs, air filter, fuel filter. Replaced most of the vacuum hoses with silicone, and replaced the injectors with rebuilt matched set of bosch OEM injectors. It smells while i'm driving very rich, like it is in limp home mode.
Do I need to start replacing wires in the harness (or the whole harness)? It looks like it has been replaced with a newer one already judging by the insulation. Ideas?
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
kcteun wrote: 20 Jun 2019, 21:48started surging at idle and then dying at every stop when warm.
It's been some years, but unplugged AMM...if same symptoms, then its related to AMM.
I may have one...it was working when I decommissioned my 1984.
