bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Re: What did you do to your Volvo today? (now Sticky)
Post by bmdubya1198 »
Washed the daily last night and put her in the garage to fix the sunroof that seems to be leaking. I discovered some water under the front floor mats, always fun...
Also removed the SC901 and amp in preparation to list this car (saving that for an 850 T-5R I’ll eventually have!). I need to thin the herd if I’m ever going to build something interesting!
Ocelot
Year and Model: 1998, S70
Has thanked: 61 times
Been thanked: 17 times
Post by Ocelot »
So today I decided to install my old amplifier and subwoofer into my S70. But... when I opened the bonnet I couldn't find any holes in the firewall to guide the big red wire through (the one that comes directly of the plus terminal of the battery).
I've searched the repair database, Google, YouTube, er cetera, but I can't seem to find any good clues/pictures of where to look. Do you guys have any tips for this Dutchie?
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
bmdubya1198
There are pass-throughs on the firewall on the driver and passenger sides. If you look under the main fuse box (may need to remove it), you'll see a piece of corrugated hose with a rubber piece on the end with nipples that can be cut off to run wires/hoses. There is one located on the passenger/right side of the car in the same area, just look down low on the strut tower.
Inside, you'll find it under the dash behind the main connector panel on both sides.
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Does the SC901 work in the 850s? I would rather like one but was under the impression it needed a bunch of additional pieces to get it working. Oh, and thanks for the brake line info!
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
I cleared the P0600 code on my ‘00 V70 for the hour-plus drive to Queens, and it was fine. Then cleared it again for the return trip, and it didn’t reappear while driving. I’ve ordered the ECU removal tool in the hope that cleaning it might solve the issue.
In the meantime, Decided to buy my cousin’s 2003 Toyota Corolla with 45k miles — for which the dealer had offered $300. That’ll provide the lady of the house with air conditioning while I look for refrigerant leaks.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
bmdubya1198
Cookeh wrote: 16 Jul 2019, 04:02 Does the SC901 work in the 850s? I would rather like one but was under the impression it needed a bunch of additional pieces to get it working. Oh, and thanks for the brake line info!
It does. All you need is a factory amp of your choice and the wiring harness for it. I used the 4x50 watt amp that mounts under the passenger seat. You just need to run the wiring up through the console to the radio and plug it all in. Pretty easy job.
Additionally, you can add the Dolby sound processor and the center channel speaker and dash, but it's not necessary. A lot of people say it's worth adding because it sounds really good, but comparing my GLT to my R (R has the center channel and sound processor stock, I never installed those in my GLT) I prefer how the GLT's system sounded. Then again, I may have a blown speaker or two in the R. I haven't bothered to check yet.
I love how the SC-901 sounds, much better than any aftermarket system I've heard in these cars.
Has thanked: 1505 times
Been thanked: 3818 times
brunocerous wrote: 16 Jul 2019, 07:54 I cleared the P0600 code on my ‘00 V70 for the hour-plus drive to Queens, and it was fine. Then cleared it again for the return trip, and it didn’t reappear while driving. I’ve ordered the ECU removal tool in the hope that cleaning it might solve the issue.
HEy - you shouldn't be ordering Volvo tools, Jersey. We have a programs for NY NJ friends and family.
Ill sign an affidavit that you can bring back her cool AC with a mere three more parts Volvos this summer.
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
New discs all the way around, 302mm upgrade up front and new lines
Only issue I ran into was the new pads rubbing :? I ended up putting the old pads back in, they weren't that old anyway (a millimeter thinner than the new ones)
Also got my squeaking dash out to find out the tabs are looking brand new :lol:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
bmdubya1198
Finally washed the S90 after almost 5 months of ownership and drove it into the garage. I also popped on the piece of door trim that was missing, all the clips were broken and I got some from the junkyard last week. Tomorrow I'll put on the good passenger mirror glass I have (original one is gray... seems the finish peeled away many years ago) and maybe drop the transmission pan to diagnose the whining pump. I'm pretty sure it's dead, but who knows... maybe I'll be able to clean it up, replace the filter, and have it working well again.
After a quick drive up and down the street, the car shifts pretty well. I honestly think this is the first time I've driven it off the driveway since I bought it... I guess that shows I have too many cars!
FLBoy
Year and Model: 1999 C70
Post by FLBoy »
Two weeks ago I removed the radiator, intercooler, intake manifold, and PCV system. Last weekend installed a new PCV system, cleaned the throttle body, intake manifold, and engine. Today, after work, I started reinstalling; the radiator and intercooler are bolted in. Tomorrow, start connecting the plumbing with new hoses and clamps.
1999 C70 Convertible White 63K
