Troubleshooting- Car will not enter closed loop, getting 16mpg. No driveability problems. Car pulls hard and does not smoke, idles normally.
P0133- Front o2 sensor slow response
---Already replaced the front o2 sensor with new correct spec Bosch unit, code thrown again on first drive.
P01505/P1507- Idle out of spec/ IAC signal.
---No apparent vacuum leaks, idle holds 840- 870 rpm consistently. This code appeared only AFTER I installed the new o2 sensor. A clue?
Current culprits:
-Small vacuum leak/ injector seal leak
-Bad or dirty IAC
-o2 sensor wiring fault or incorrectly connected
-Running an ECU I found at a yard labeled '96 850R'. Car was a 96 Turbo (HPT)- should match? ECU problem?
Thoughts? I'm going to smoke the intake when I am at my shop next as a first step.
96 850 Turbo- P0133, P1505, P1507
- Has thanked: 1505 times
- Been thanked: 3818 times
Certainly start by returning the ECU to the correct one and seeing
The R has more boost, different injectors (?) eliminate that as a source of codes.
Remove each piece of vacuum tubing and replace any more than 5 years old to eliminate leaks - visual is ineffective.
