1998 S70 Turbo T5 - P0133 code
Car just threw this code and I assume it is the O2 sensor as all rubber lines were replaced about 6,000 miles ago by PO. Car runs fine, not sure of MPG as it is my sons car. Any trick to accessing the sensor connectors? One is completely covered by the airbox tube while the other is partially obscured. How much stuff do I need to remove to access the connectors?
- Has thanked: 2199 times
This FCP link may help you figure this out:
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
The air box is all you really need to remove. Unclipping the main fuse box and pushing it out of the way along with removing the intake tube will give you more room. Spray some wd-40 or silicone on the connectors. They get stuck and can break if you pry too hard.
Knows enough to be dangerous
Lots of parameters are involved. However, I want to ask a little about the Volvo V90. If anyone has any information, please let me know. I'm so happy to hear about it.
- 1001 Views
Last post by kimothyanne
- 883 Views
Last post by RickHaleParker
- 1185 Views
- 1128 Views
Last post by theWIFES_S70
- 53 Replies
- 8377 Views
