2005 V70NAM56 CATHERINE 496197 Manual 5 into code A981 Saurus 15inch wheels
Forum rules
Has thanked: 1609 times
Been thanked: 4063 times
Removed rear wheels, inspected parking brake shoes/drum
All ok
Removed center console, adjusted parking brake to 4 clicks full application, tested release
viewforum.php?f=9
Oil change filter Mobil 1
New air filter
Will send oil to Blackstone
Screen Shot 2019-01-03 at 8.42.22 AM.png (131.46 KiB) Viewed 10669 times
Replaced Cabin air filter CUK 2850 at 1228xx
Tailgate latch is inop. No continuity from REM connector pin to tailgate solenoid wire at solenoid. Probable wire loom failure. viewtopic.php?f=9&t=89038&p=519123#p519123
26 OCT 2019
With cooler weather, the previously seen BCM-0700 has stopped occurring
viewtopic.php?f=9&t=85197&p=482578&hili ... BS#p482578
Xmodex repair is $750 for both module and Pump
https://xemodex.com/us/product/brake-co ... -volvo-p2/
And it’s a New Year, 2020
CanBus H L infor from swedespeed
https://forums.swedespeed.com/showthrea ... LVO-CANBUS
CANfoolery
So in the past few months there has been alot of talk about 4C, good and bad. Some want to remove everything to do with it on their cars, some want to use different shocks, some can live with it etc. Then there is talk of fooling or tricking the system somehow. This leads me to my post. Are there swedespeeders out there who would be willing to "tag-team" sniffing the CANBUS to understand messages and possibly manipulate/trick/control/read/whatever 4C and other parts of the car? I figure we can use this thread as a master to post ideas, wish lists, deciphered CAN messages (that would be nice!) etc. then maybe we can get somewhere to modding the car's core systems.
I have already purchased a http://www.canusb.com device and have been trying to detect activity on my 04 SR without any luck (although I haven't really dove into it....yet).
To start here is some basic info:
04' - CANL - speed = 125kbps, CANH - speed = 250kbps
05+ - CANL - speed = 250 kbps,CANH - speed = 500kbps
Main car units (i.e. ECU, CEM, ABS, SUM etc) operate upon CANH bus
CANL reserved for things like DIM, windows, audio etc
CANbus is detectable @ the OBD port (reportedly)
CANbus is POSITIVELY accessible via a green 10pin square connector in trunk (RTI connector)
Other posts of interest:
https://forums.swedespeed.com/z...age=1
https://forums.swedespeed.com/zerothread?id=38911
Here is a small wishlist of things that I'd like this project to lead to and/or accomplish:
fob - yellow - turn on drls("follow me home" lights) or open windows/sunroof
advance button - turn off dtsc completely
write to messages DIM
make horn beep on lock/alarm engage
cancel bulb out message
cancel 4c suspension not working message
2020 maintenance record
abscate wrote: 22 Nov 2015, 12:24 Tailight failure, both sides
Diagnosed and repaired
https://www.matthewsvolvosite.com/forums ... =9&t=73056
Rinse and repeat on this one today, same fuse in REM
Added one liter make up oil at 126400, 10 March
25 July 127600 oil and filter change 10W-30 Mann. These oil changes are killing me
Fixed driver leather seam
viewtopic.php?f=9&t=94473&p=548524&hili ... 70#p548524
Temp sensor specs
Ny state inspection 128600
Had to replace rear rotors for rust and also clean fuse 1 in REM to fix inop reversing lights
New rearvtotors and pads, flushed 750cc brake fluid
Ordered on FCP Shipments
Order #:
R525030404
It’s a new year! 2021
May 15 r/r front pads and rotors , push 500 ml brake fluid, mileage on fronts 50,000/7 years
Rotors order on FCP /R829699128, pads from earlier stock
28 September. 134600
Loss of power for 5 seconds at speed, popped ECM261A and ECM2100
Points to fuel pressure sensor, PEZm, or wiring
7 October 135600 oil change filter change 10W30
Replaced reworked ABS pump. Bushing insertion with pick and large flat blade
Replaced fuel pressure sensor
Possible rear wire harness problems. Two inop items
Rear lid lock solenoid
Reversing lights..will troubleshoot signal from CEM TO REM
3/10 reverse light switch 10/48, 10/55 reverse lights
2022 service records
Jan 5 NYSI 138038 rotate tires, RF boot leak noted
Circling back on brake module
viewtopic.php?f=9&t=85197&p=592379#p592379
16Feb Battery weak. 4/2014 dated. No start, charged overnight. Will try to nurse it to Spring, replace in fall 2022
Abs part number More part numbers
Alldata 30793453
Supersedes Supersession(s): 30683501; 30742262
Skandix 30793452
And part numbers on car is 30643982
July 9 replaced ignition lock cylinder
viewtopic.php?t=100432
4 November 5W-40 Castrol syn oil change 142250
Fuse 5 needs cleaning again, no tail lights
viewtopic.php?p=613170#p613170
********Upcoming 150k service: coolant change, spark plug change, serp belt
Put a Curt hitch onto car, November 2022
viewtopic.php?p=618899&hilit=Curt+hitch ... ne#p618899
Air guide part numbers
