Power steering rack
stevebg
Year and Model: 2004 V70 d5
Power steering rack
Post by stevebg »
Hi all , I'm in need of some advice from the guros on here plz , my 2004 V70 d5 has developed a leak of power steering fluid , had a mechanic friend have a quick look at it and he confirmed it's the rack , question is which rack does my car have , I've heard it could be 1 of a few , how can I tell which rack I need , and does anyone have a good appropriate rack for sale , tks in advance
MDK
Year and Model: 2004 S60R
Been thanked: 41 times
Post by MDK »
Well bg.. you never mentioned where it's leaking. The lines have "O" rings. Is it the lines themselves where it's crimped together? Or is it at the inner tie rods? I'm of the crowd that anything can be fixed... Not just swap it out. They have... What I've discovered... A thing called .. rack assist. Something about variable speed...To find out you'll need your full VIN # to see which one you have but I'd bet... Being a T 5 .. that's what you got. Hope this helps... MDK
stevebg
Post by stevebg »
Hi mdk , it's a d5 not T5 , it's leaking out the rubber boots on the inner tie rods so am guessing it's blew the seal out the rack end itself ,
MDK
Post by MDK »
Oh? It's a diesel? I'm guessing that is what that means. In any case, a rack is a rack. So.. I'm not sure I can help you that much. I'm in the states. And looking up parts I don't getting a listing for a d5. In any case.. if you can get a hold of Ratnalle.. he's one of the moderators here and I think he is in Sweden. He'll know how to help..I did manage to find a seal kit from eBay motors for S80 S60 V70 .. you could try fcp euro too.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I would expect it to have the SMI rack. Also look for a speed sensitive sensor if existent (less probable)
stevebg
Post by stevebg »
Tks oragex , is the speed sensor visible while the rack is on the car tks
oragex
Post by oragex »
Yes, you will see a wire from the top of the rack box, with a flash light and the wheel full turn
Looks a bit like this https://i.ebayimg.com/images/g/xMMAAOSw ... -l1600.png
