95' 850Turbo NoPower-Windnoise-Turbo Topic is solved
Volvo Fan
Post by Volvo Fan »
By the way, is there a clamp that need to hold this insert tube in place?... Test drove the car & it was ok then the tube came off again? Causing the old problem.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1252 times
Post by matthew1 »
Service light comes on independently from any external input -- it's just a timer.
It can be set (minimum interval to max. interval) something like 12 months/x-miles to 18 months/x-miles.
Also -> Amazon link
Volvo Fan
Post by Volvo Fan »
Could I reset.., & how??
I had a check up before its time & I think the dealer didn't reset again?
matthew1
Site Admin
Post by matthew1 »
I don't know how to reset on '95s. On 1996+ you need to reset with a reset tool (dedicated) or laptop with OBDII software.
Perhaps someone who knows will chime in.
As for the clamp, I'd go to an auto parts store and get a bunch of general purpose screw clamps and put one on the tube.
Also -> Amazon link
Volvo Fan
Post by Volvo Fan »
I just did that and I believe it should hold. Just in case, I will go by the dealership parts depot and make sure I am using the right type. I guess I will have them reset that service light as well.
Thank you all for your assistance...
I will make sure I share the knowledge to our dedicated Volvo loyalist!!! 8)
potroast
Year and Model:
Post by potroast »
you can reset the service light manually on 1993-1995 Volvo 850's. Only the 1996+ require a tool.
Here's the instructions:
http://www.volvospeed.com/850slight.htm
Volvo Fan
Post by Volvo Fan »
Thank you very much!
