It does not. Your best bet would be either YouTube or another image/video hosting site.
Need 98 v70 xc driver seat wiring diagram
- Has thanked: 304 times
- Been thanked: 517 times
Re: Need 98 v70 xc driver seat wiring diagram
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
Finally got a minute to review the diagrams.
There are only 4 wires to worry about here:
Seat Power 12 VDC (+) is Green/Red protected by an auto reset
thermal circuit breaker in position 11C/39 - Amps Unknown...
(Anybody have the cover off their fusebox that can have a look?)
Ground is the black wire next to it on the same connector.
Put 12 volts and ground to these two leads, plug in the control switches
and it should work. ( You may have to power up the Yellow/White
wire that shows a connection to the key activated accessory
overload 105 relay 2/30 - Not sure).
Seat Heat Power 12 VDC (+) is Yellow/Red @ 25 amps
Ground is the big black wire on the same connector.
You can tape and stow the extra wires.
- Has thanked: 1498 times
- Been thanked: 3810 times
You can find such a video oil Robert Spinners Volvo channel, of course.bmdubya1198 wrote: ↑30 Jul 2019, 15:04I've always been curious to try that at the junkyard...BEJinFbk wrote: ↑30 Jul 2019, 13:49 The little round unit I’m talking about is a charge encased
in a flying saucer shaped can on the outer SIDE of the seat.
IIRC, it’s an inch or two in diameter and maybe an inch thick.
The safety clip should be attached to the inside of the cover
panel and it slides betwen the actuater and the seat frame.
Again, it’s found under the side cover that the seat controls
are mounted in. It blows a small charge under impact that
travels up a small tube to the side bag. Hit it, you’ll know!
Start at 2:30 if you share my 15 second attention span for videos. And remember...
PHP...#southern accent
Like , share, and subscribe ...
I don't know how I've never seen that video... thanks for sharing! Hahaha
- 2015 Views
Last post by legalstuff
- 1512 Views
Last post by volvolugnut
