99 T5 - questions about boost control: boost maps, why the adjuster Topic is solved
projectsmorol
Year and Model: 2008 c30
Re: 99 T5 - questions about boost control: boost maps, why the adjuster
Post by projectsmorol »
Playing with with waste gate tension rod, especially when you do not fully understand it, is not the wisest move. I'm not pointing fingers
or judging someones intelligence. Waste gates open at a preset tension based on the spring in the gate. 4,7 psi etc. at those pressures the gate opens allowing exhaust gas to bypass the compressor and either be returned to exhaust system, intake charge or atmosphere(racing)
It is one of many components set up in a system of checks and balances to control boost pressure, spikes, overboosting etc.
Use a boost controller and you are effectively "tricking" the ECM into thinking that waste gate is at a different pressure than what it really is. These items can be used, and they do help produce gains, IF you know what you are doing.
One the flip side, if you've got a ton of money lying around and just want to play a bit of roulette, spin the barrel and see which part fails first.
All of these adjustments by the way are minute. 1/8th to a 1/4 turn at a time with logs in between to see what effect the adjustment made.
It's a slippery slope.
2008 C30:
Darton wet sleeves|CP Carrillo pistons&rods|Upgraded injectors|K16 turbo|3"downpipe|ELEVATE:cat back|custom intake|turbo intercooler hard pipe|lower motor mount|turbo blanket|intake plenum|downpipe wrap|dual bypass valve|lowering springs|rear camber arms|do88 FMIC|Porche 70mm TB|BMC air filter|MAF upgrade|Turbosmart waste gate|meth injection|IPD brake lines|NGK iridium 1 step colder|APR head studs|AEM AFR/Boost Gauge|Hilton Tuning
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
I had no intention of running the actuator at anything besides factory spec.
