Hello everyone
Today my car died as I was driving "hard" in the mountains.
There was no specific sound made, but there was an awful smell and the lambda light came on.
I got a complete loss of power and when I stopped the car it idled erratically.
When I tried to start it it cranked but didn't start.
I'm stranded in the mountains (French Alpes-Maritimes) away from any good known mechanic.
Thanks for your help.
Car died, stranded 1000km from home, please help... Topic is solved
bronco
- Year and Model: 1998 V70
- Has thanked: 49 times
- Been thanked: 24 times
Where are you stranded ?Fiodor wrote: 13 Aug 2019, 14:19 Hello everyone
I'm stranded in the mountains away from any good known mechanic.
- Fiodor
- Year and Model: 1997 V70 2.0 T5 AWD
- Has thanked: 13 times
- Been thanked: 9 times
In France in the Alps (in a village called Sigale), approximately one hour from Nice.
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Try to disconnect the maf sensor connector and see if it will run.
Other than that could be that hose from turbo popped off.
Is coolant level ok?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Fiodor
Coolant OK
Oil OK
Disconnecting the MAF didn't change anything yesterday.
The car now starts but idles roughly and shakes a lot.
I've checked the TB and it's fine, how could I tell if the belt slipped ?
Edit: the lambda light comes on too
Oil OK
- jvl
- Year and Model: 2006 V70 2.4D
- Has thanked: 20 times
- Been thanked: 8 times
Maybe ignition or fouled plugs?
I once experienced this on my 2000 (electronic ignition, no rotor like the '97) and the misfiring also led to a code related to the lamda sensor.
Are all plugs, cords, rotor and cap OK? Did the no start situation happen during rain?
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
- Fiodor
Everything ignition related (except the coil) was replaced with OEM parts 3000km ago.
The car miraculously started working perfectly fine after giving me a P0270 (injector circuit low) on cylinder 4 (the plug was a bit moist).
I cleared the code and it didn't come back!
I'm thinking that the mountain sways at 60mph + the ethanol in my reservoir (I'm driving E85) detached some scrap from the reservoir walls which eventually ended in the fuel filter/pump/injector (which would explain the lack of pressure in the fuel rail).
Thanks for the help, I love this forum and its inhabitants
- Has thanked: 1614 times
- Been thanked: 4078 times
Its good you broke down in a Nice Neighborhood.
- Has thanked: 317 times
- Been thanked: 531 times
Glad you're back up and running!
- 9 Replies
- 2378 Views
- 17 Replies
- 6626 Views
- 1057 Views
Last post by mechaman1
- 11 Replies
- 2922 Views
Last post by lizardheart
- 1509 Views
Last post by rspi
