96, 850 N/A hesitation issue
Danonly55
Year and Model: 1996 850 sedan
Has thanked: 23 times
Been thanked: 4 times
Post by Danonly55 »
I searched the forum and found nothing for my particular model, The car started hesitating at idol and during acceleration. The red arrow showed up on dash but then went out. Car still didn't feel right. Yesterday I reset the #2 O2 sensor code and drove it about 3 miles with no issues. Any Ideas where I should start ?
2014 Ford 3.5L ecoboost XLT
1995 Volvo 850 wagon GLE
Life is tough, but it's tougher when your stupid'
" John Wayne
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
Start with looking for vacuum leaks.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
Has thanked: 312 times
Been thanked: 818 times
Good call from greg850r. Replace those crumbling, 20 year old rubber vacuum hoses ...
A guide: viewtopic.php?t=65002
Has thanked: 1611 times
Been thanked: 4072 times
Every 30,000 miles you should evaluate ignition parts on a P80
Spark plugs (replace if they are Cu type, regap expensive type where possible)
wires
Coil
Distributor cap
Rotor
Those last two should be shiny copper clean and bright on all metal parts
Danonly55
Post by Danonly55 »
abscate wrote: 02 Sep 2019, 06:33 Every 30,000 miles you should evaluate ignition parts on a P80
wires
Coil
Distributor cap
Rotor
I have replaced all ignition parts less than 2k miles ago, I ordered a PCV system kit today, It's due anyway.
" John Wayne
Danonly55
Post by Danonly55 »
erikv11 wrote: 01 Sep 2019, 22:04 Good call from greg850r. Replace those crumbling, 20 year old rubber vacuum hoses ...
A guide: https://www.matthewsvolvosite.com/forum ... hp?t=65002
Sweet link with pics , Thank you !!
" John Wayne
Danonly55
Post by Danonly55 »
Ok I just hooked up the OBD reader and started the car, The code it's throwing is 0102 not sensing air flow, looks like I may need a MAF sensor also?? Car did not want to stay running, Had to feather gas peddle to keep running.
" John Wayne
p0102 may be a bad MAF or very commonly, a vacuum leak. Usually the rubber elbow behind the corner of the intake manifold, on the passenger side. Called "line 3" in that link up above.
To test the MAF, unplug it with the car off, then start it up. Without a MAF the ECU will go into default air:fuel mixture, running a little rich, but should run just fine if the MAF is the problem. This will set a MAF code which you'll need to reset after the test.
Danonly55
Post by Danonly55 »
erikv11 wrote: 02 Sep 2019, 22:38 p0102 may be a bad MAF or very commonly, a vacuum leak. Usually the rubber elbow behind the corner of the intake manifold, on the passenger side. Called "line 3" in that link up above.
Ok great I will give that test a try and also check the #3 vac line. I'll keep ya posted. Thank you
" John Wayne
Danonly55
Post by Danonly55 »
Danonly55 wrote: 03 Sep 2019, 08:30
I performed the test, and it acted as you said. The #3 vac line looked and felt in good condition.
" John Wayne
