XC90 D5
XC90 D5
Hi can any one give some advice my XC90 has no acceleration when in gear but has acceleration in park. And also can you tell me if the gearbox has a dip stick please any help will be appreciated.
wanderdüne
- Year and Model: 2004, 2006 XC90 2.5T
- Has thanked: 6 times
- Been thanked: 45 times
We don't have the D5 in the US, but yours might share a common transmission. What year is your XC90?
edit* If your XC has the Aisin Warner TF-80SC automatic transmission, then no, it doesn't have a dipstick. Here is a video that documents the process for that transmission:
Is it showing the gear selection correctly in the instrument cluster?
Hi its a 2006 but I can't find any think about the gearbox I also having trouble with the acceleration it accelerates in park and neutral but not in gear I've just cleaned the ERG Sensor and all pipes that was clogged with carbon
wanderdüne
*wait, do you mean that the engine rpm's don't rise when the car is in Drive, but that they do when it is in Park and Neutral?
What about in reverse?
wanderdüne
Ok, you do have the (TF-80SC) Automatic transmission.
Here is a link to the U.K. Volvo Manual online (from Volvo); the info for that transmission is on page 243:
https://az685612.vo.msecnd.net/pdfs/c56 ... tp8193.pdf
Do you have access to a VIDA/DiCE code reader?
If you haven't done, probably a good idea to cross post on here: https://www.volvoforums.org.uk/ as yours is a diesel. Also, maybe someone on there has a VIDA/DiCE and could help you out with a code reading. Many Volvo codes will not illuminate the check engine light.
Also, looks like member cheshired5 on the UK forum can help you out with purchasing VIDA/DiCE https://www.volvoforums.org.uk/showthre ... light=vida if you have no one local. It's really less than a dealer reading, so pays for itself right away.
