Hello Volvo Owners!
I have a 2012 Volvo S60 T5 FWD and it needs tires. I lived into Houston and never had to worry about snow, but I recently moved east and now I'm not sure what types of tires to buy for the winter. Do I need a snow tire (I'm in Virginia), or will an all season tire work? I hate to go to a tire shop uninformed!
Susan
Tires for Volvo S60?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Of course, the answer is "it depends." Are you in a mountainous area of Virginia that frequently gets a lot of snow? Do you have lots of experience driving in the snow? Are you a lead foot, or can you shift down and avoid sudden steering inputs and braking action while maintain a safe following distance? Do you have a long gravel driveway that you want to be able to get up? Do your current tires (I am assuming all season radials) have a lot of remaining tread depth, or are they almost down to the wear bars. The advice I will provide depends on your answers.
Bear in mind that, although people who generalize are always wrong, your fellow Virginians aren't great drivers in the snow. This is because they don't get a lot of practice at it. So, another factor in your calculus may be the need to avoid other drivers who drive poorly in the snow and, most likely, do not have vehicles equipped with snow tires.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- E Showell
Were I in your shoes, I would look to find a used set of snows already mounted on wheels and use them through the winter (assuming you have some place to store a second set of wheels). Then pick up some new all season radials in the spring mounted on your existing wheels.
You will definitely notice better handling in snow with snow tires and it is much better not to be mounting and demounting tires on the same wheels to change between snows and all seasons.
'95 855 auto (sold)
'95 855 auto (sold)
pshdars
- Year and Model: 2012 Volvo S60 2.5
Hello E Showell!
Thanks for the reply. I appreciate SO much for taking the time to respond to my post. Here are the answers to your questions:
- I am about 1 hour from the mountainous areas of Virginia, so, likely, I will not be in this area with any frequency.
- I DO have significant experience driving in the snow (I grew up in the mountains with feet of snow).
- I do NOT a lead foot (learned my lesson early on--black ice). I understand downshifting (when and why).
- No long driveway, no gravel.
- Just measured tread depth and it is 16/32 all the way around and yes, all season radial.
E Showell wrote: ↑01 Oct 2019, 13:45 Of course, the answer is "it depends." Are you in a mountainous area of Virginia that frequently gets a lot of snow? Do you have lots of experience driving in the snow? Are you a lead foot, or can you shift down and avoid sudden steering inputs and braking action while maintain a safe following distance? Do you have a long gravel driveway that you want to be able to get up? Do your current tires (I am assuming all season radials) have a lot of remaining tread depth, or are they almost down to the wear bars. The advice I will provide depends on your answers.
