Did you know? 🤔
P0172, P0302 & P0410
blacklistedbully
Year and Model: 1998
Has thanked: 6 times
Been thanked: 0
United States of America
blacklistedbully
Post by blacklistedbully » Fri Oct 18, 2019 11:00 am
Hi all. Recently found this site. Awesome! Here's my issue:
Daughter's '98 C70 2.3L turbo recently showed codes for misfires in all 5 cylinders and P0172 (Bank 1 rich) Can't remember the rest, but I did replace the MAF which seemed to work. No more rough idling...car ran great. Cleared codes. This lasted about 2 weeks, then back to rough idle. Codes read P0302 (cylinder 2 misfire) & P0410 (Secondary Air Injection System). All spark plugs seemed in good condition, though the gaps were not checked. Compression good.
Had her clean the old MAF with MAF sensor cleaner and reinstall, sent the Delphi AF10311 MAF back for refund. Car seemed to run a little better, but for less than 1 day. Back to the rough idle. Had her clear codes to see what would happen. Got:
P0172, P0302 & P0410. Freeze frame info only on P0302, and is as follows:
  • Engine speed - 840 RPM
    Calc Load - 1.6%
    Coolant - 210 F
    STFTRM1 - -.8%
    LTFTRM1 - -6.3%
    Veh Speed - 6 MPH
    Fuel System 1 Loop - Closed
    Fuel System 2 Loop - N/A
My thoughts include:
  • Check cylinder 2 spark plug gap
    Might it still be just a bad MAF, and the Delphi replacement was a dud?
    Check wires, caps & rotors
    Have replaced some vacuum line connectors/elbows that were obviously leaking, but thinking another leak may be the problem. Get a smoke test?
    Possible air pump failure?
Money is tight at the moment, so I'm hoping to avoid falling into a money pit, only to find this car needs more $ than it is worth.
Any suggestions would be greatly appreciated!
misha
Has thanked: 56 times
Been thanked: 134 times
Serbia
misha
Re: P0172, P0302 & P0410
Post by misha » Fri Oct 18, 2019 4:51 pm
These cars will run ONLY on OE and OEM sensors.In this case...it's Bosch.
Delphi(aftermarket) will not work.
It's better to use oe sensor from junkyard than any aftermarket ones.
Maf connectors on these cars are prone to failure....even if pins in connector looks ok you will need a small precision screwdriver to minimize gaps on all pins in the connector.
Connecting and disconnecting the actual connector a few times should help to determine if it's bad.
If car runs ok untill next re-start after re-seating the connector....it's not the maf.
Also....if car runs better with Maf disconnected....then it's bad(or the connector is bad).
These users thanked the author misha for the post:
blacklistedbully
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
blacklistedbully
Been thanked: 0
blacklistedbully
Post by blacklistedbully » Sun Oct 20, 2019 6:31 pm
Misha, thank you. I'll give it a try. In the meantime, I found notes of previous codes. They were P0300 (random multiple misfires), P0303 (misfires in chyliner 3), P0304 (misfires cylinder 4), P0305 (misfires cylinder 5), P0172 (Bank 1 rich) & P0455 (gross leak in Evap system).
Also, on her last visit home, right b4 she left I had to quickly replace some rotted vacuum line elbows & connectors. I noticed the air pump check valve was disconnected from one end. Like a dummy I removed it to inspect it, not paying attention to which direction it was going. It's 1/2 white, 1/2 black, and comes from a hose that appears to extend from the front of the car, by the radiator towards I assume the air pump.
https://www.eeuroparts.com/Parts/8406/C ... e-9135666/
Anybody know which side faces the pump? Is it possible having this check valve either failed or installed backward is causing the problems and/or has led to an air pump failure that is in turn causing the problems?
Has thanked: 318 times
Been thanked: 986 times
Trinidad & Tobago
Post by abscate » Sun Oct 20, 2019 7:36 pm
Blow through the valve. One way will flow the other won’t. Draw an arrow with sharpie in the direction it flows
Point the arrow away from an air pump
Point the arrobw towards a source of vacuum
These users thanked the author abscate for the post:
blacklistedbully
Link To Volvo Glossary
blacklistedbully
Been thanked: 0
blacklistedbully
Post by blacklistedbully » Sun Oct 20, 2019 8:16 pm
abscate, thank you!
Trinidad & Tobago
Post by abscate » Sun Oct 20, 2019 11:52 pm
...welcome!
Don’t forget to post back the white black convention here for reference!
(Oh my God Karen! You can’t just ask why purge valves are white!)
blacklistedbully
blacklistedbully
Been thanked: 0
blacklistedbully
Post by blacklistedbully » Thu Oct 24, 2019 12:37 am
New developments. No new codes, but daughter reports the car would not start on first two tries this morning before starting on the 3rd. Also said drive back home felt like engine "stumbled" some during acceleration on the freeway. AC, lights, radio, etc. working.
Her BF is guessing bad ignition coil. But no codes for running lean...in fact, running rich in bank one. Plus, still only showing misfire in cylinder 2. Correct me if I'm wrong, but on a '98 C70, doesn't the ignition coil serve multiple cylinders, and if so, would a bad coil be likely if only cylinder 2 is misfiring?
Trinidad & Tobago
Post by abscate » Thu Oct 24, 2019 6:01 am
From another car make I found that the check valve convention is flow is enabled from white to black, blocked from black to white.
So
Air pump ..........white/black ........air injection
Engine vacuum........black/white.........purge valve or other vacuum motor
blacklistedbully
blacklistedbully
Been thanked: 0
blacklistedbully
Post by blacklistedbully » Thu Oct 24, 2019 6:46 pm
FCP Euro lists a Bremi as OE. Any idea if that one works?
Trinidad & Tobago
Post by abscate » Thu Oct 24, 2019 8:32 pm
Correct. On a -1998 a misfiring single cylinder is cap, rotor, wire,plug,or engine mechanical.
blacklistedbully
