Rear Caliper 10mm or 11mm mounting holes..? 5003813 5003814
- Has thanked: 1505 times
- Been thanked: 3818 times
Re: Rear Caliper 10mm or 11mm mounting holes..? 5003813 5003814
If you putbtwo right calipers on your car will pull rightuntil you end up in Yellowstone, but at least you will avoid Helena...Go Cats!
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
Well I generally use only left calipers so it swings left to Missoula! Go Griz!
