Hi, I recently acquired a scan tool and I've been looking at all the available data.
Something which seems odd is that the short term fuel trim is always exactly zero. When I graph it it's a flat line, with min and max values of zero. Is this normal? I was expecting a jagged line continuously moving about a percent either way. That's how the MAF looks.
Also, the long term fuel trim is -18.0%. So, tending rich, but not yet setting a code. Would a bad fuel pressure regulator be contributing to this? Leaky injectors? The air filter is clean.
fuel trims question
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
- Year and Model: Many Volvos
- Been thanked: 76 times
Most ECU's are programmed to trip the CEL at a 20% departure from the default.
850oldschool
Okay, so what I seem to have figured out here is that my P1308/EFI-444 is causing the engine to run open loop. I cleared the code, started the engine to see if it came back instantly (it didn't), then flipped down to short term fuel trim and found it working normally. Reading "fuel system 1" returned "CL-FAULT". When the code returned fuel system 1 changed to "OL-DRIVE". So the P1308 is preventing it from shifting to closed loop operation.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
That is not right and I suspect the scan tool is not interpreting it. You can have fuel trim inhibited for faults for O2 sesnor and for some other components where they know fuel trim correction will not be possible.
- greg850r
- Year and Model: a long list
- Been thanked: 26 times
When my fuel trim flat lined it was the front 02 sensor.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
850oldschool
I've spent hours reading about OBD2 over the last 2 weeks, and I have to say that the fuel system status readout in the generic OBD2 mode is by far the least documented part of OBD2. What I know so far is that "OL-DRIVE" is when the ECU makes a decision to temporarily suspend closed loop operation during WOT or ? I can't really find any specific info about the exact trigger.
"OL-FAULT", it turns out, is when the system is unable to to enter closed loop, due to something like no signal from the front O2 sensor.
And what does "CL-FAULT" mean, and what triggers it? I still don't know.
- Been thanked: 4064 times
OBD “ standards only cover basic diagnostics. The specifics of engine management are proprietary code for each manufacturer. That’s so they can defeat emissions testing and hope no one will discover it.
850oldschool
If it's this hard to figure out what is throwing the system into open loop operation, I would say that the system doesn't
even qualify as "basic diagnostics".
- 12 Replies
- 3166 Views
Last post by pkc303
- 6168 Views
Last post by Maurice EVO
- 3261 Views
Last post by jakeb123
- 262 Views
Last post by pgill
- 8365 Views
Last post by Struikrover
