MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
bmdubya1198 wrote: 01 Nov 2019, 11:54
abscate wrote: 01 Nov 2019, 10:57
You can buy from a dealer at 80% of ask if you show up with that sweet green smell of cash.
Thats a nice stick shift S70 T5 at $3500. If you bought a $500 one, you would be in deeper to get to that condition.
At $3,500, it would probably be a great buy if it's up to date on maintenance. It looks like a really nice car.
The front and rear ride height looks like an AWD. At that age they usually have a sagging rear end.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
MoVolvos wrote: 01 Nov 2019, 19:50 The front and rear ride height looks like an AWD. At that age they usually have a sagging rear end.
It is sitting kinda high... maybe it has new quick struts, those tend to raise the front end a lot. Those things are awful... gave my cousin's V70 a gasser stance!
But the car looks level at least.
MoVolvos
Post by MoVolvos »
bmdubya1198 wrote: 02 Nov 2019, 08:36
"Gasser"? Is that opposite of Ricer?
EDIT: Tires also look one size up in term of the Aspect To Width Ratio (50 to 55 Series)
bmdubya1198
MoVolvos wrote: 02 Nov 2019, 08:47 "Gasser"? Is that opposite of Ricer?
Hey, I actually found a Volvo gasser! Like this, but a little less dramatic.
https://images.app.goo.gl/cM8f1KfvvVd94vm8A
MoVolvos
Post by MoVolvos »
bmdubya1198 wrote: 02 Nov 2019, 17:25
That's really messy when it come to racing as you can't compare Apples to Apples.
The official class name was “Gas Coupe & Sedan” class, which was soon rounded off to just a Gasser class. A Gasser is (or was) basically a stock production type vehicle with a hopped-up engine. A stock car with a non-stock engine as it were. And the engine did not need to be the same brand as the car. For instance, an old Ford coupe with a later model Oldsmobile engine would fit right into a Gasser class.
http://www.georgeklass.net/gassers.html
bmdubya1198
MoVolvos wrote: 02 Nov 2019, 19:43 That's really messy when it come to racing as you can't compare Apples to Apples.
Drag racing gets REALLY technical, I'm not too familiar with it. Great article there!
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
MoVolvos wrote: 02 Nov 2019, 19:43 The official class name was “Gas Coupe & Sedan” class, which was soon rounded off to just a Gasser class. A Gasser is (or was) basically a stock production type vehicle with a hopped-up engine. A stock car with a non-stock engine as it were. And the engine did not need to be the same brand as the car. For instance, an old Ford coupe with a later model Oldsmobile engine would fit right into a Gasser class.
That is like the term Hot Rod. Hot Rod was original a poor boy's game. He could not afford a car so he would cobble one together from whatever parts he could get cheap or for free. The frame might be a Ford, the Cab might be a Plymouth, the nose clip might be a Cadillac, the engine might be REO. He would weld everything together to build a car.
The term Hot Rod referred to the Hot Welding Rods use to bring it all together.
Active
Past
MoVolvos
Post by MoVolvos »
Not Quite CL.
2004 Volvo S60 R LEATHER! RARE! *MECHANIC SPECIAL* $2,999
Occasional Bump in transmission. Carfax shows minor accident
https://www.neweracars.com/750_V2019091 ... *-for-sale
Carfax - On Page Of Link Above Also
https://www.carfax.com/VehicleHistory/p ... YX42368710
bmdubya1198
MoVolvos wrote: 05 Nov 2019, 21:51 Not Quite CL.
Looks decent, but $3k for a "mechanic special" with a dying AW55 is pretty steep. It looks like it's been well maintained from that Carfax, though.
MoVolvos
Post by MoVolvos »
bmdubya1198 wrote: 06 Nov 2019, 07:38
6 owners and a bump on the driver's side front bumper and a bump to the entire rear bumper. Potentially abused and lost value due to the accidents?
