Hi all! i just bought a 98 v70r and im wanting to do the na manifold and throttle body. Sorry if i missed it....but ive looked through other threads, and i haven't seen which model, and years will work. I found a na manifold at the junk yard but it looks the same as my turbo one( just 1 model # different)??? Does someone have part numbers? Also my R has the cable throttle body, and not the Drive by wire.
New to the turbo 5 cylinder world, so any help is much appreciated!!
Thank you
N/A Manifold upgrade on v70r
- clinton775
- Year and Model: 98 V70r, 64 Amazon
- Has thanked: 1505 times
- Been thanked: 3818 times
Is this a known hack?
Volvo engineers may have designed different runners for a system being pulled in by 13-15 inches HG engine vacuum vs one under 16 psi front end boost?
- clinton775
Its definitely a know upgrade. Snabb sells a kit, i just thought i could save some money, and source the parts myself.
http://www.snabb.us/Big-Bore-Turbo-Inta ... p_102.html
Last bumped by clinton775 on 14 Nov 2019, 05:24.
