Ok, so heres the symptoms and my reasoning:
My Temp gauge has been acting crazy shortly after I purchased the car. The needle would at times seem to act normally, rising normally to just a hair beyond mid-line, only to plummet to Zero, then rise back to approx mid-line, then plummet, repeat and repeat (I know its not a malfunctioning cluster gauge because I could hear and feel the engine adjusting when the Temp needle would plummet). So clearly something is off - but is it the sensor or the connector?
But yesterday the sensor did something Very interesting. Upon starting an absolutely cold engine, the Temp shot right up to mid-line, right away. Now given that these sensors are Negative Temp Coefficient sensors (the Resistance goes Down as they heat up), the fact that the needle shot up right away tells me that it can't possibly be the sensor connection. Reason why - any kind of connector issue would cause an Increase in resistance (corrosion, crud, partial open), yet the sensor is acting right off the bat as though there's a resistance Drop. This, along with the fact that there is NO evidence that the gauge in the cluster is malfunctioning tells me that it is HIGHLY likely to be the sensor itself.
Furthermore, although I will change the thermostat because I don't know how old it is, it would be physically impossible for even a trashed thermostat to cause a reading of instant heat on a cold engine.
So it MUST be the sensor!
What do you guys think?
850 Turbo Coolant Temp Sens, or Sensor Connector ?
- Has thanked: 1611 times
- Been thanked: 4072 times
Pull off the connector and check the pins for corrosion. Then pull the part number,search forum here for that part number and the resistance table, and confirm it Errors of about 10% are ok
The new part is about $50
Pick and pull less
I think I have one of my 1998 parts car , too. If you are tapped out and fighting the man, it’s free, otherwise market value or something in between.
Pick and pull less
- RickHaleParker
- Been thanked: 980 times
Intermittent electrical shorts will lower the resistance. Conductive corrosion in parallel with the temperature sensor will lower the resistance.
Active
Past
Past
Nick777
- Year and Model: 1995 850
- Been thanked: 3 times
Abscate - thanks for the info and especially for the offer! I'm not quite in financial dire straits (yet!) so I'll save your offer for if and when I really need it!
RickHaleParker - very interesting! I wasn't considering that there could be conductive corrosion, even though I'd imagine that resistive corrosion is far more likely. As to intermittent shorts, also another good observation. As a matter of fact i wonder if that is in fact going on in my situation - on one occasion I observed the temp needle shoot all the way to the tippy top even though the engine was clearly not overheating (just started more or less). An intermittent short would plummet the resistance to near zero, which would explain the needle jumping to the top like that!
- RickHaleParker
Resistance also has conductance. Resistance is some where between a perfect insulator and a perfect conductor.Nick777 wrote: 16 Nov 2019, 10:26
Resistance and Conductance are reciprocals of each other, like Yin and Yang there is some of the other in each.
Active
Past
Past
Isnt resistance more Buddhist, like Ooooohhhhhmmmmmmm?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
You're baaaadddddddddd =P
2023 Lexus RZ450e -66k
- Has thanked: 311 times
- Been thanked: 817 times
If you need to buy another ECT, this is another part for which the cheap aftermarket ones often don't work.
Driving through NJ all week MON TUES. WED
Give me a PM and see if we can connect
- 2086 Views
Last post by MyS40T4
- 2387 Views
Last post by sleddriver
- 823 Views
Last post by loveMy850
- 11 Replies
- 9101 Views
Last post by oragex
- 2608 Views
Last post by prwood
