Motive Bleeder How High Is Too High? Topic is solved
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 6 times
Been thanked: 45 times
Post by wanderdüne »
Looks like I may have run low on fluid when bleeding my brakes after a pads and hoses replacement. I didn't read up on it; looks like I should have had the brake pedal depressed. Hate when that happens. VIDA says if the system is run dry, to power bleed at 29-43psi. Seems pretty high; is this ok? It will max out the Motive at 30psi/
*edit: I am asking if this pressure is ok to run through the ABS and hydraulic system; not the bleeder.
Been thanked: 471 times
Post by cn90 »
The ABS module can handle high pressure.
The problem is the reservoir, above 20 psi you risk blowing it up. Search bmw forum for this.
I use my ATE cap + air compressor + 10 psi for bleeding.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
You think air got inside the master ? There is a video on Youtube with a trick - basically the guy puts a hose on each caliper bleeder, and brings the end of the hose above the master, so in theory the air bubbles will be forced to travel to the caliper and into the hose. I did the same but only at the right front caliper - and it seems this has purged the air from the master - only my impression ,can't say for sure
As for the Motive Bleeder, I too bleed at 10psi or so and it's just fine, no need to put pressure like on a tire. I don't remember reading about having to keep the brake pedal depressed ?
wanderdüne
oragex wrote: 24 Nov 2019, 11:15 You think air got inside the master ? There is a video on Youtube with a trick - basically the guy puts a hose on each caliper bleeder, and brings the end of the hose above the master, so in theory the air bubbles will be forced to travel to the caliper and into the hose. I did the same but only at the right front caliper - and it seems this has purged the air from the master - only my impression ,can't say for sure
I think I may have gotten air in the ABS. The trick makes sense; I've seen the reverse bleeding that some do, kind of the same concept.
wanderdüne
I bled the brakes once more @25psi and got a couple of bubbles through the LF caliper. Still a little soft afterwards. I went out and pulled 4 aggressive stops from 35-40mph to try to activate the ABS and now the brakes operate normally.
