PSI for Motive Brake Bleeder?
hans747
Year and Model: 1998 V90
Has thanked: 2 times
Been thanked: 2 times
Post by hans747 »
Hey friends!
Quick question: what is the recommended PSI for a Motive power bleeder on a single-circuit system?
Here's the backstory:
My son and I are bringing a 1966 122s back from the dead. So far, we have:
  • Replaced master cylinder
    Replaced fron calipers
    Replaced all rubber hoses
    Replaced front rotors
    Replaced brake pressure switch
    Replaced rear brake shoes
    Replaced rear brake cylinders
I was having a hell of a time bleeding the brakes, so I bought a Motive bleeder. The system is better, but it still needs one or two pedal pumps to build pressure.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
I’ll be interested in the answer to this as well.
So where else could there be any air in the system? I’ve read about people “priming” or pre-bleeding a new MC. Is that necessary with these?
Has thanked: 2200 times
Been thanked: 1852 times
Been an awful long time since I had a 122S, and 123GT. Don't recall ever having any particular issue with bleeding brakes. If you have a brake booster then that may be your culprit. The diaphragm internally fails or splits.
Only issues I had were the booster, a stripped thread on a rear brake adjuster that blew out on me and then failing seals. Brakes were really good otherwise with excellent stopping.
