Herman and Operation 30MPG
jfife83
Year and Model: 97 850na, 00 s70na
Post by jfife83 »
HI there... you describe the exact problem I'm having with acceleration on my 2000 s70...can you tell me where the fuel pressure regulator is located?
2000 s70na 228k mi - daughter's car
1997 850na 87k mi - daughters
inherited from little old lady
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
jfife83 wrote: 03 Dec 2019, 08:36 HI there... you describe the exact problem I'm having with acceleration on my 2000 s70...can you tell me where the fuel pressure regulator is located?
Hey Jfife83, it's on the fuel rail.
Here are some handy dandy pictures.
My issue was the vacuum line that you can see me holding in the first picture. The line had swollen and lost its air tight connection.
You need to pull the two bolts on the fuel rail and, replace the vacuum line. Yours may be different depending on model year but they function the same way.
Hope that helps!
Has thanked: 311 times
Been thanked: 817 times
The fuel pressure regulator is not on the fuel rail for any S70 cars. That position will have a fuel pressure damper installed, there is no vacuum line to those and I don't think I have ever heard of any problems with a damper.
On a 2000 S70 the FPR is either down on the steering rack or back by the fuel filter. However the FPR still has a vacuum line like on this 850, and you can check the vacuum line once you find the FPR. Also common is the FPR fails inside, you'l know this if the vacuum line reeks badly of gasoline.
Has thanked: 1609 times
Been thanked: 4064 times
My 1999 S70 (Denso engine management) doesn't have a vacuum controlled FPR - the fuel pressure is regulated by pump modulation only.
I think the 2000 continues this, but Ive learned there are enough variations that I don't know about to be careful.
Look at the vacuum line diagram on your hood to see if you see the FPR
callahanoffroad
Okay here's the promised pics of the new headlights.
As you can see... You can see! :lol: :lol: :lol:
I can’t see the headlights
jfife83
Post by jfife83 »
Herman...abscate and erikv11
Thanks for the info...will let you know what I find
I know I mentioned the hood sticker, but use that to go looking for your components, not as Gospel
Volvo put a 1998 sticker on my 1999
callahanoffroad
abscate wrote: 05 Dec 2019, 19:04 I know I mentioned the hood sticker, but use that to go looking for your components, not as Gospel
I'll second that. Mine says '95 everywhere but is mechanically a '94. Which made for some confusion the first year I owned it
befarrer
Year and Model: 1998 V70 AWD
Been thanked: 24 times
Post by befarrer »
I don't even have a sticker, or any reminants of one.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
