Documenting a problem
Prewarning: we had a heavy snow here and with lots of slush I noticed that if STC operated for more than a few seconds, I would get an ABS light. I also noticed if Imrookie-clutched it and let the revs go below 500 rpm, I would get the same fault. After a few seconds of running the fau;ts would clear.
I drove the car to Boston with no faults two days later
On the way home, if I flashed high beams to guide a truck back in, I got the ABS fault, then just headlights did the same thing. Turning lights off , then faults cleared again in a few seconds
I made it home just before dusk wth lights off.
I measured 12.5 v at battery at 0 Celsius
I put the battery on charger overnight, and now have driven it for a week with no faults
Battery history is near end of life . 6 years and 105k miles in service
Alternator is relatively new, 2 years 40k miles
Video of failure recorded below.
One minute video of fault at at speed
1999 V70T5M56 Elizabeth Voltage Bus problem [Old battery on last legs] Topic is solved
8EDB34AD-9DA3-4412-8C9B-4465BD595F65.MOV- (38.17 MiB) Downloaded 422 times
- Has thanked: 987 times
- Been thanked: 1075 times
You have received full value from that battery. Time to replace. Thanks for good documentation of poor voltage faults.
I’m going to try top it off each weekend and nurse it through winter. It will be fine in summer.
A real grownup will just replace it now , of course
A real grownup would just replace it of course. Whenever I take a dollar out of my pocket, George Washington blinks for all the light, though.
It’s a good learning lesson on how a battery can be good enough to start a car at 20F, but not be good enough to run an electronic era car reliably. She is starting and running fine three weeks later, after a solid charge.
We should make it rule number 1 of late model Volvo ownership: The battery voltage must be sufficient to keep electronics happy. It is not 1960 when battery test is cold starting capability.
The same battery is cranking and running fine in 20 F weather, so I’m trying to get one last winter out of it. It will get a good charge on weekends to keep it happy, then get relegated to boat duty where it will just light some LEDs
You make a good point here. There are batteries and BATTERIES. We used to use batteries until they would not crank the car any longer. (Side note: I once had a battery explode with a hole in the case. It measured about 10 volts, but would start and run 1964 Ford truck.)
Batteries now are good for boat lights and old cars without extensive computer systems.
BATTERIES are needed for cars with major computer systems that require fully charged voltage just to keep the vehicle running well. When BATTERIES get old they degrade to batteries.
This has been registered as official MVS lore (tm)
Thanks, volvolugnut
Still running that old battery. With Corona shut down, I’m putting all the cars on charger every 2-3 weeks
It’s showing 12.2 Volts at 75F, so a bit less than 50% capacity by voltage, I’m guessing Current capacity is even less
- 303 Replies
- 37346 Views
Last post by bmdubya1198
- 1633 Views
- 28 Replies
- 5739 Views
- 12 Replies
- 1474 Views
- 11 Replies
- 5913 Views
Last post by oragex
