Her first CEL
RickHaleParker
Been thanked: 958 times
Re: Her first CEL
Post by RickHaleParker »
Sveedy wrote: 14 Dec 2019, 08:02 What do you mean by " full editor " ?
Where you been typeing your messsages is the standard editor. Full editor is a editor mode that has more options, including file attachments. look below I marked the button to get into the Full editor. Full editor is more like a word processor.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Way cool ! Thanks !
I'll give that a try.
1999 V70 GLT
Sveedy
Post by Sveedy »
More fun with lights and codes. When I just had the CEL cleared there was another code: No DTC definition found. Consult service manual.
The CEL has stayed off so far.
Also I have noticed that when I punch it enough to engage the turbo, the ABS light comes on. Only time that light comes on.
I think that's it.......for now :)
Mucho Gracias !
1999 V70 GLT
RickHaleParker
Sveedy wrote: 14 Dec 2019, 10:36 Also I have noticed that when I punch it enough to engage the turbo, the ABS light comes on. Only time that light comes on.
The P80s are notorious for cracked solder joints at the ABS connector.
I an thinking:
When you step down the engine torque moves the ABS harness, opening solder cracks on the PC board at the ABS connector.
Sveedy
Post by Sveedy »
Yes Rick that sounds about right. I noticed that it seems to have more to do with the sudden movement, either by the turbo kicking in or the tranny down shifting. I think I saw a post about having the ABS module repaired but I'm not sure.
1999 V70 GLT
crlande
Year and Model: 240DL;850;S70
Been thanked: 36 times
Post by crlande »
https://www.midwest-abs.com/Troubleshooting.php
Matty Moo on this site is the man!!
Sveedy
Post by Sveedy »
Neat ! Thanks ! I guess there goes another $ 100 + but if it solves the problem it's a deal :)
1999 V70 GLT
Sveedy
Post by Sveedy »
Just wanted to say " Thanks for everybody responses ! ". I've been on other forums where you feel like your alone in a field of crickets.
I would " Thank " formally so it would go to your signatures but guess what ? I can't figure that bit out either :)
Truly appreciate all your help,
Paul
1999 V70 GLT
Has thanked: 1507 times
Been thanked: 3823 times
Sveedy wrote: 15 Dec 2019, 07:48 Just wanted to say " Thanks for everybody responses ! ". I've been on other forums where you feel like your alone in a field of crickets.
Paul
crlande
Post by crlande »
Well I'm ok without a list of thanks, thumbs, smileys and whatever else is out there. Enjoy that car Sveedy.
